Dry Camp on one Charge...?
ELK
How long can you comfortably dry camp before you have to attend to the trailer?
2015 T@B Max S. TV: 2015.5 Volvo XC70.
What do you mean by "attend".0
Gonna need more info to answer - you just gonna let the camper sit with nothing running or you gonna use it, if so, how?0
(Yes...I can see why you need more info!!) I mean, like, say I'm at a dog show for 4 days and there are no hook ups....Will my battery last? Will my tanks fill up? Just me and a dog or 2 in the trailer.
2015 T@B Max S. TV: 2015.5 Volvo XC70.0 -
I would be living in the trailer and watching some TV...
ELK said:(Yes...I can see why you need more info!!) I mean, like, say I'm at a dog show for 4 days and there are no hook ups....Will my battery last? Will my tanks fill up? Just me and a dog or 2 in the trailer.
The stock battery that comes with the T@B would typically only last 24 to maybe 36 to 48 hours. You will need a way to recharge your battery. Solar or generator are the normal choices.ELK said:I would be living in the trailer and watching some TV...
Your fresh water tank is only 11gallons (2014/15 models), gray water is 19 gallons, black water is 5 gallons. I used my black water tank for 4 days for #1 only during the evening and night, and it didn't fill up, but I used the Campground facities during the day. Using the shower very frugally will not fill up the gray water tank in 4 days, but it depends on how much water you put down the drain.Verna, Columbus, IN
If you were to not use anything (no TV, etc) but having the fridge run, it may last. I parked mine at a campground outside San Francisco - didn't want to pull it thru the city and narrow streets - for three days with just the fridge going and it was fine when I got back. Disclaimer - Your mileage may vary.0
Fridge was on propane, right?PXLated said:If you were to not use anything (no TV, etc) but having the fridge run, it may last. I parked mine at a campground outside San Francisco - didn't want to pull it thru the city and narrow streets - for three days with just the fridge going and it was fine when I got back. Disclaimer - Your mileage may vary.
Yep, fridge on propane.0
Hmmmm. thanks. Verna, you got me thinking about solar....although this IS Oregon....
- 144 Events & News
- 414 Service/Maintenance & Recall Notices
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
