Battery switch etc.
I have a new BOONDOCK. Have not even been camping, yet. I have solar. All worked fine until I turned off the batteries with the switch. Now the solar won’t charge, the batteries won’t charge and I can only run shore power to use anything electrical in the rig. Of course, I did turn the batterie switch back to the on position. I checked the breakers and the fuses. Could it be the switch? Any ideas would be very helpful. Thank you.
  • marleecampsmarleecamps Member Posts: 161
    Did you accidentally trip the circuit breaker in the external storage compartment where the battery switch is also located?  On my 2021 400, it's a small black box with a yellow lever located on the wall straight ahead when you open the door.  So easy to bump when moving things around in the storage bay.
    --Marlee
    2021 Tab400 Boondock; TV 2015 Jeep Grand Cherokee; Minnesota
  • MaxMax Member Posts: 6
    I will go check this very moment. Thank you.
    You are amazing! That is precisely what I did! You win an extra large cookie! Thank you so very much. I found no information about this, yet you knew exactly the problem. I can’t begin to thank you enough! Many, many thanks for your generous time and advice. What a relief! Max
    Simply paying it forward.  This forum has helped me out in so many ways.  Keep asking questions as needed.
    --Marlee
    No worries, the main battery circuit breaker next or near the battery cutoff switch getting accidentally tripped, has been an issue since the first TaB400 had them installed, all are located in the rear passenger storage locker.  You would think nüCamp would have put a notice about this in the instruction manual kit, or dealers including this in the customer walk through of the camper.
  • BinghiBinghi Member Posts: 359
    I still want to install a cover over that switch. Hard as I try to keep things away from it, they seem to creep toward it. It’s a real trap.
  • marchulemarchule Member Posts: 46
    I had this happen to me, too.  Too further complicate things the wires were "draped" in such a way that they hid the switch thus obscuring the problem.
    2018 320S / KIA Sorento 3.5 V6  - 2022 400 Boondock / KIA Telluride 3.8 V6  -  Utah
  • DocmarieDocmarie Member Posts: 3
    I have a 320s boondock and this may have happened to me also, but is the circuit breaker somewhere else on my model? I don’t see it at all
  • Yoshi_TABYoshi_TAB Member Posts: 471
    Hi,
    What year is your TAB 320?  Also, what is the problem?  Your solar is not charging your battery?  Same as above, it was working until you turned  your battery switch Off/ON?  TAB 320's have no DC circuit breakers, only fuses.  The only circuit breakers are for the AC power located in your WFCO.
    2025 360 CS (awaiting delivery)
    Southern Maryland
  • bjn2bjn2 Member Posts: 103
    @Docmarie are you getting no DC power through the battery? Assuming that, and that you have the main power cutoff switch turned to the on position, you'll want to check the fuses in the wires that connect to your battery (look for black rubber inline fuse holders), and then check the two fuses related to the battery in your WFCO panel. Fuses F6 and F7 are the ones to check there.
    Utah-based
    2023 T@B 320 S Boondock
    Thank you so much for your help, I now know where the external fuses are for the battery and indeed that is what it was! Now the alde isn’t heating…perhaps I blew two fuses. Checking that next! Love this forum!
