Axle camber seems excessive
13»
  • Dave_JDave_J Member Posts: 5
    2020 boondock lite
    i had excessive wear and paid to replace axle with no good result.
  • sruffsruff Member Posts: 2
    Reviving an old thread here, but I've got an issue with terrible tire wear (looks like camber is way out), and I believe my trailer is in the age range this thread refers to. I've got a non-boondock 2019 T@B400 I picked up used a year ago. The mileage was unknown, but the tires were not original (2023). They looked quite good - lots of tread left.
    We just got back from a two month, 8.5k mile trek out west and I pulled the wheels/hubs because I wanted to inspect the brake shoes.  The right (passenger) tire was unevenly worn, but not drastic. The left (driver) is nearly bald. Because water was often unavailable at sites where we stayed, we did a fair bit of travel with a full fresh water tank and I expect that at least partially explains the difference in the two.
    I suspect I'm going to have to buy a new axle - we're definitely out of the original 5 year period and aren't the original owner - as well as new tires. And here I was worried about brake shoes...I can do the work, but it's still going to be a substantial out of pocket on the axle.
    I just want to check that the definitive diagnostic is the resting camber? I can get my son to help me measure toe as well.
  • manyman297manyman297 Member Posts: 1,411
    Maybe I'm wrong but I thought the torsion axles have a 10 year warranty. Not that it matters if you aren't the original owner. Still, something for people to consider if they have to make a claim.
    2021 400 BD
    2020 Tacoma TRD Off-Road
    I might enquire directly with Dexter about the warranty, who knows, maybe they'll honor it.
    For the Boondock owners: I see only a 3500lb and 5100lb axle option. I'm considering switching to the heavier axle anyway since I suspect that we are getting up near the 3500lb limit with the tanks full, and I'm also contemplating adding weight in the form of a kayak rack and bike rack, at which point I'm sure we'll be past the 3500 limit.
    Has anybody upgraded to the Toflex #11 5100lb axle? Thoughts on this? I haven't measured dimensions yet and I'm hoping it's a drop-in replacement.
  • qhumberdqhumberd Administrator, Moderator Posts: 652
    My 2019 400 Boondock shows this axle in the spec sheet (#10F 4K Torflex)
    2019 NuCamp &@B400 ‐ Boondock Lite
    CATEGORY SPECIFICATIONS
    Exterior Height for Clearance 8' 6"
    Exterior Length End to End 18' 3"
    Exterior Width for Clearance 7' 4"
    Interior Height 6' 9"
    Ground Clearance Lowest Point 11.5"
    Top of Ball to Ground at Level 22"
    Hitch Ball Size 2"
    LPG Tank Fitting RV Type I Acme
    Stabilizer Socket Size 3/4" socket ‐ 6 point
    Tank Capacity ‐ Black in GAL 12
    Tank Capacity ‐ Grey in GAL 18
    Tank Capacity ‐ Propane Tanks One 20#
    Tank Capacity ‐ Water in GAL 30
    Battery Configuration Two 6V AGM 224‐AmpHrs
    Water Intake ‐ Potable 5/8"
    Water Regulator ‐ Potable None ‐ Use external at 50 psi
    Weight ‐ Axles GAWR 3,900
    Weight ‐ Curb 2,690
    Weight ‐ GVWR 3,700
    Weight ‐ Hitch# Tongue Wet 400
    Weight ‐ Hitch# Tongue MAX 460
    Weight ‐ NCC (Carry Capacity) 1,010
    Wheels ‐ Brakes Electric
    Wheels ‐ Axle Dexter #10F 4K Torflex
    Wheels ‐ Lug Nut Torque 100 foot pounds
    Wheels ‐ Rim Code/Size #L55205R / 15" diameter x 6.0" width J collar
    Wheels ‐ Tire Pressure COLD 50 psi
    Wheels ‐ Tire used for Specs 235/75R15
    Wheels ‐ Tires mounted Rainier Apex ST APC‐X ST235/75R15
    Wheels ‐ Type Black Aluminum
    Wheels ‐ Spare Rainier ST 205/75 R15
