In the spring it'll be our first time re-lubing the axles plus we have to replace the vent cover for the waste water tanks as the original one broke.
I just want to make sure I'll be ordering the correct grease for the axle (which I think it is, based on a nuCamp video) and dicor for the roof:
And, does anyone have experience using this particular vent cap, rather than the "standard" one:
Lippert 360 Siphon RV Roof Vent Cap                ----------------------------------------------------------
Jay and Kat
Tow vehicle:  2022 Jeep Gladiator Sport S + tow package
Camper:  2022 T@B 400 Boondock w/Norcold 3-way fridge
0 ·
E-Z-Lube Lubrication Spec pdf attached
Jay and Kat
nuCamp uses Valvoline GM Multipurpose. I think as long as you use a lithium based grease you’ll be fine.
My "get it through the winter" fix was to take the top of a new vent, screw it to one of the "snap" posts and the post the old cap was screwed to, the put a cover over the camper.
Once spring gets here we're going to pull the camper home remove the old dicor and vent, glom on the dicor where the new vent base will be, screw the vent down, glom on more dicor on top and especially around the screw heads, and we should be good. I hope.
Jay and Kat
