Loose "bolts" attaching tongue to trailer
I recently noticed that I could hand spin the two "bolts" that are part of the bracket that attaches the tongue of my 2021 TAB400 to the body.
The bolts on the other side do not spin. They don't look like normal bolts. Any idea as to how to tighten them? Thx, Mark
2021 T@B400 Boondock
2008 Toyota Tacoma
Silver Spring, Maryland
  • AnOldURAnOldUR Member Posts: 1,554
    They're called huck bolts and once assembled should not loosen up. We had several fail on our 320S. I drilled them out and put in 5/16-18 bolts with nylon locking nuts.
  • madtroutmadtrout Member Posts: 63
    Thanks for the info. Always an adventure with NuCamp
    2008 Toyota Tacoma
  • pthomas745pthomas745 Administrator, Moderator Posts: 4,238
    I had the same basic issue, but with the huck bolts that attach the frame farther back just behind the door.  I had them replaced with stronger bolts last summer.  (I can't remember exactly the size, but I learned a lot from previous posts on this).  This is @AnOldUR thread from before.
    Thanks for that additional info. I'll have to wait til the snow melts to get under the trailer and remove the bottom cover to get access to the loose Huckbolts and replace them. Can you imagine owning a NuCamp product and not being mechanically inclined? NuCamp seems to have really deep-seated Quality Control issues.
    2008 Toyota Tacoma
    edited January 2024
    madtrout said:
    ... NuCamp seems to have really deep-seated Quality Control issues.
    nuCamp is not perfect, but I don't agree with this statement. Social media can take a rare problem and amplify it to where it can appear to be the norm. The good thing is that potential problems are brought to their attention sooner so that they can be evaluated and acted upon.
    I'm fairly certain that nuCamp is not directly responsible for this, but can demand more from their suppliers when issues are found.
    Hi bergger, Thanks for your input. I'm glad you have had few troubles with your TAB.
    Our's was a Covid build in 2020, and while we love our TAB and have put over 15,000 miles on it,  we have had numerous problems. We even had to have the factory replace our black tank. We've had numerous leaks, warped cabinetry, and the refrigerator had to be replaced. That said, NuCamp has fixed everything under warranty even after the expiration of the warranty. We do love our TAB, but it is not without its faults.
    2008 Toyota Tacoma
  • manyman297manyman297 Member Posts: 1,389
    @madtrout I get your frustration as we also had NUMEROUS issues (including some safety issues) with our 2021 400. To the point that I'm not sure we'd entertain buying another BRAND NEW rig but maybe a used one that somebody else has worked out all the kinks.
    With that said, I do have to say Nucamp went above and beyond making what they could right. They sent numerous replacement parts (several pieces of cabinetry which had to be extremely expensive to ship). They even compensated me for my time that I spent fixing things and relied on my honesty of hours spent to reimburse me. I doubt any other manufacturer would've done that.
    So it's hard to fault them at least on their corrective measures but yes, the quality control in the RV industry is non-existent. I think most manufacturers take a book from Detroit automakers in the 70s...just get it out the door and we'll fix it when something eventually breaks.
    2021 400 BD
    2020 Tacoma TRD Off-Road
    Just heard back from NuCamp about this. Here is their response:
    Hi Mark,
    I would want this checked out by a technician, preferably a mobile technician to ensure it is safe to tow. We won't be able to provide DIY instructions as we would need to be on site to inspect the unit to be sure.
    Best Regards,
    Creed Hostetler
    2008 Toyota Tacoma
    The reply you got @madtrout is different than what Creed told me a year and a half ago. Possibly because I presented him with a method to correct the problem as apposed to asking for one?
    edited January 2024
    I think I'll fix it your way. Seems pretty straight forward. Thanks, Mark
    2008 Toyota Tacoma
    A little fun with the right angle grinder made quick work of the huckbolts. I drilled the holes out to 5/16 and installed grade 8 hardware. Seemed a little bit of overkill, but all is fixed nicely now. Let hope the TAB leaves me alone until camping season starts.
    2008 Toyota Tacoma
