I recently purchased a 2017 T@B 320S and need to add a trailer hitch to my 2006 Suzuki Grand Vitara which is able to tow about 3,000 lbs.
Can someone tell me how to best proceed? I've located a trailer hitch on Amazon that is custom-made for my car, and a simple universal 2" trailer hitch mount, but my understanding is that I need a wiring system that is able to activate and control both the lights AND the braking mechanism on the 320S. Is there a simple way to add everything I need?
I received an estimate from a local RV dealer that it would cost $1,369.00 for them to install a trailer hitch, including the hitch receiver, wiring harness, brake controller, wiring harness, etc. This seems excessive to me. Is there a less expensive way to proceed without cutting any corners?
Thanks for your help. This is my first post on this forum. I look forward to being a part of this helpful, thriving community...
David Sunfellow
2022 T@B 320-S Boondock "
@ngel"Sedona Arizona
0 ·
2022 T@B 320-S Boondock "@ngel"
Sedona Arizona
Your Suzuki is not really built for towing so the quote you received does not seem that outrageous as there will be a lot of Labor Billing and several parts.
The Suzuki will need in addition to the Tow Bar Receiver/Hitch:
-=- Wire from battery to rear bumper
-=- Special wire harness installed to transfer the lights to the trailer
-=- A 4-pin to 7-pin convertor (as special harness is only a 4-pin)
-=- And a brake controller . . . I'd suggest a wireless like the Curt Echo
As for actual towing with the Suzuki. You will be at the limit for the vehicle so do plan your routes/speeds and vehicle/trailer loading. For example the TAB maximum weight rating is 2900# . . . not highway towing with the water/waste tanks full and not over packing for the trip, the on-the-road weight could be several hundred pounds lighter.
Typical 2006 Grand Vitara numbers are:
=-= Max Trailer weight: 3,000# (trailer brakes required)
=-= GCWR: 7,500# (Suzuki and trailer combined weight)
=-= GVWR: 4,630# (maximum Suzuki can carry including fuel)
=-= Curb Weight: 3,582# (includes fuel)
=-= Payload, Cargo+Passengers: 1048# Best Case
For Actual Payload, subtract the trailer towing hardware (35#) and trailer tongue weight (~260#)
so you, your passengers, and all the stuff in the Suzuki must be <= 750 pounds.
Sedona Arizona
Most folks will find that adding up the weight of everything that did not come from the factory with the trailer and tow vehicle will easily exceed 500 pounds. Add driver and passenger and it will be difficult not to exceed rated capacities. Anything being operated at or near it's maximum capacity has to be handled very carefully, requires constant attention, and is constantly at risk of unanticipated situations putting everyone and everything at risk. IMO this added stress and safety compromise takes a lot of pleasure out traveling.
Be careful. Stay situation aware. Have fun...
I have taken my 2009 CS to the local scale several times to satisfy curiosities and, in preparation for a floor replacement, removed and weighed everything that was in our "ready to travel" trailer. I speak from experience and actual measurements.
The 200 pound difference you mention (published info varies) really doesn't change the fact that the OP will end up with a TV/trailer package that is dangerously close to, likely exceeding MAXIMUM rated capacity. Probably okay for short local utility trailer chores but not a good condition for long distance, highway travel with a high profile travel trailer.
Many long time forum members have related much improved towing experiences when they upgraded to a higher capacity TV from small marginally capable vehicles.
Can the set up work? Sure, with care and experience. In almost all cases, these inquiries are from inexperienced new trailer owners looking for safety based recommendations.
IMO - Suggesting a marginally adequate, possibly inadequate TV will be fine is a disservice to them and the other motorists they encounter.
https://tab-rv.vanillacommunity.com/discussion/4748/how-much-stuff-do-you-carry-in-your-t-b-cargo-weights
Sedona Arizona
WRT the vehicle, the GV may be a candidate for a transmission cooler to prevent the thing from burning up in the Sedona heat.
WRT @MuttonChops suggestion to consider the Echo wireless controller....hmmm. First, there is not a consensus that a wireless controller is a defacto choice. Many of us prefer a simpler, less costly and arguably more reliable hard wired controller that does not require agonizing interface with other devices and an extra unit in the TV. Then, presuming a choice to use a wireless unit, the Curt unit may or may not be one to select. You should spend a few minutes looking at the related discussions on this forum. Use the search feature. You will find that the Curt is not a consistently recommended piece of kit.
