Awning Parts
Tross2023
Member Posts: 79
We are making a eyebrow type awning, anybody know where to get the curved metal frame?
Thanks
tom
Thanks
tom
2024 Hyundai Santa Cruz and 2018 T@B 320S
Check out Tent Pole Technologies. They can custom build just about anything according to your specs. I purchased replacement sections for my PahaQue awning pole a few years back. IIRC, prices and shipping were both very reasonable.
I strongly suggest getting a metal pole - not fiberglass. One of the best mods I ever did was replace the fiberglass pole in my XL Visor with metal. Bought the metal pole sections on Amazon for about $24. You will need a longer length because its going to be an awning. Would be happy to measure my PahaQue awning pole for you.2016 Outback 320
2024 Ford F150 Supercrew short bed.1 -
@Tross2023 I also bought an aluminum pole for my visor and have no regrets. I believe that I needed 19’ of pole, so I bought a two pack off Amazon and added the necessary sections from one to the other, cutting the last section down to get the correct length.Azarxis Tent Pole Repair Kit... https://www.amazon.com/dp/B07H29JQQV?ref=ppx_pop_mob_ap_share2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red1
thanks to all, having trouble commenting today2024 Hyundai Santa Cruz and 2018 T@B 320S0
Hope you're having a better day today.2016 Outback 320
My awning took a beating during a storm last weekend. Three of my aluminum poles are pretty well shot. Does anyone know where I could check to replace them?
Tent Pole Technology. https://www.tentpoletech.com/Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
The weak points are typically the smaller diameter short connector tubes, not the longer pre-bent tubes. If those are the areas that are bent, a good hardware store sells the correct diameter tubing. That and the correct size drill bit and you can replace the connector tubes. I think it's key to maintain the gap between the longer tube ends when you make them so they have room to bend in the next wind storm.Rich2019 T@b 400
2025 Toyota Highlander 2.4L TurboBellingham WA0
