'23 TAB 400 heater ?
Hammick
Member Posts: 80
I was under the impression our TAB 400 had heater strips in addition to the heat pump. I have tried the furnace function on our Dometic thermostat and nothing happens. So are the heat options just the Alde and the heat pump?
Yes.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
The Alde works very nice.2018 320CS-S
"Just Enough"1 -
We have never used the heat pump function. The Alde heating has worked great when we have needed it, which isn’t that often.
Ken / 2023 Tab 400 “La Bolita” (39,000+ miles) / 2024 Toyota Sequoia0 -
We use the heat pump as a back-up in the event of an Alde failure.
I think the heat pump is more for spring and fall type cold.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Unless something changed from 2021, there is an option on the control panel for heat pump, but the air con doesn’t have one installed. At least per my manual. Only option is Alde, wether you use electric or propane to operate it.2021 Tab400 boondock, 2019 Jeep Grand Cherokee Trailhawk0
Yes our '23 has the heat pump. I don't know how I got the heat strips in my head. Must have been from the Airstream Basecamp we looked at before buying the TAB 400. Thanks for all the replies.Kevin_K said:Unless something changed from 2021, there is an option on the control panel for heat pump, but the air con doesn’t have one installed. At least per my manual. Only option is Alde, whether you use electric or propane to operate it.0 -
The bathroom of our 2019 400 has a heated floor in the bathroom that gets its heat from the Aldi. When the Aldi is heating the main cabin, it's also heating the bathroom floor. I would think that the newer 400's do the same.
Could that be what you were thinking about?Jean & Arnie Nevada
2019 T@B 400 BL
2021 Toyota Sequoia 4WD1 -
Nope. First I've heard of the heated floor but good to know. I'm pretty sure I confused it with the heat strips in the Airstream Basecamp.NorthIsUp said:The bathroom of our 2019 400 has a heated floor in the bathroom that gets its heat from the Aldi. When the Aldi is heating the main cabin, it's also heating the bathroom floor. I would think that the newer 400's do the same.
Could that be what you were thinking about?0
- 143 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 918 Tips & Tricks
