I just bought a 2023 tab 400 and brought it home. Reportedly a once or twice used trailer in late 2023 and winterized in late October.
As I was looking it over, I saw that the Alde fill reservoir was almost empty. Green fluid barely visible in the neck. It was 30 degrees out and I turned it on using propane to see if it would work. It fired up fast, burbled on and off, the fan was running on and off, and the cabin was heating up.
I looked at the reservoir and it was almost full to the top! It was still heating and so I left it on for another 15 minutes. When I shut down, the reservoir was warm and near full. It had heated nicely.
It was then I saw a stream of liquid that had come out below the reservoir on the drivers side onto the driveway.
Is it over full? Missing an air pocket? (I swear that is for hot water, not glycol). How can I diagnose?
thanks. Have been reading like crazy. Seem to have seen this symptom before, but no clear answer to the issue.
I believe it was caused by air bubbles expanding in the glycol.
The problem was resolved by turning the Alde glycol pump up to full speed for a few minutes. I could hear the bubbles flowing through the system, eventually becoming released to atmosphere once they reached the reservoir.
After a few minutes, I turned the pump back down to the 2 setting (5 is full speed).
I also gently tapped on the automatic air bleeder (located above the glycol pump) in order to bring that device back into proper service.
trailer is generally level, but may be biased a bit towards the high point reservoir.
2015 Audi Q7 TDI
Northern Ohio
The Alde fluid level should be checked on a cold system. It should be 1 cm above the min. level when cold.
Southern Maryland
2015 Audi Q7 TDI
Northern Ohio
2015 Audi Q7 TDI
Northern Ohio
2015 Audi Q7 TDI
Northern Ohio
2015 Audi Q7 TDI
Northern Ohio
2015 Audi Q7 TDI
Northern Ohio
2015 Audi Q7 TDI
Northern Ohio
2015 Audi Q7 TDI
Northern Ohio
2015 Audi Q7 TDI
Northern Ohio
is my boiler shot or maybe the flow heat exchanger? Clearly glycol is on the hot water line. How should I diagnose more, or is it already a done deal? I’m screwed?
2015 Audi Q7 TDI
Northern Ohio
2015 Audi Q7 TDI
Northern Ohio
2015 Audi Q7 TDI
Northern Ohio
2015 Audi Q7 TDI
Northern Ohio
Have you pressurized the system to see if there are any leaks in the plumbing lines/connections? If so and there are no other leaks then most likely the lines were drained and filled with antifreeze but the Alde tank was not drained and thus cracked when the water in it froze. If you have additional leaks in the plumbing then the lines were not drained and filled with antifreeze properly either. I live in a place with 7-8 months of winter and or below freezing temps. If the trailer is winterized properly with draining tanks/lines and then using a good antifreeze the Alde and plumbing lines will be fine. I have my 400 winterized for 7 or more months a year and so far nothing has broken. Hopefully this year will have the same results.
Let us know what Truma/Alde finds out when you take it to them.
2015 Audi Q7 TDI
Northern Ohio
If the FW tank is mounted under the floor, at a level below the Alde boiler, I can't imagine how any water left in the FW tank could flow upward, against gravity, without the aid of a pump. This, even if valves were at that time in a "dry camping" position connecting it ultimately to the boiler.
Secondly, it seems there could be a scenario where water from the plumbing lines & fixtures throughout (that never got completely displaced by antifreeze) could roll back down and accumulate in the boiler. < Not sure if there are any check valves in the water piping that might prevent backflow >. The 3020 model Alde boiler, I believe, holds about 2.2 gallons - not sure what the 2023 year model holds. The entire plumbing lines capacity (without the Alde boiler) volume is near that volume. So if water did roll back and completely filled the boiler and left zero room for expansion during freezing, that would imply there was somehow a lot of water inadvertantly left in the plumbing lines.
Just a thought anyway. Hope you get good news on repair.
SW Montana USA
2015 Audi Q7 TDI
Northern Ohio
