2024 Tab 400 Black Canyon Coupler Height is 21"
Hi Everyone!
I was trying to figure out the right hitch to show up with when I pick up my new 2024 Tab 400. I couldn't find this info anywhere so I contacted NuCamp and they responded right away. Excellent customer service.
In case anyone else needs this info: The measurement from the ground to the top of the coupler is 21" on the 2024 Tab 400 Black Canyon
    So that should make the tow vehicle tow ball height 20”.  You want the trailer level with the TV or slightly lower — never higher!
    Happy towing and camping…
  • MuttonChopsMuttonChops Member Posts: 1,870
    Am surprised nüCamp provided the coupler height referenced to the TOP as the standard tow ball height calculations use the Coupler Height referenced to the BOTTOM .
    Would assume if Top is 21" Bottom will be 18-19'ish inches.
    Calculation reference:
  • B0atguyB0atguy Member Posts: 239
    This should be the same for the standard 2024 400 Boondock model as well ? Black Canyon is just more solar , tank heaters and underglow lights , so the stance should be exactly the same ?
    Havent picked ours up yet , so just checking for a proper ball height for the truck .
    2024 NuCamp T@B 400 BD,  Charcoal / White
