Hi folks,
I am new here. I just got a T@b 320 and am looking to upgrade the batteries to lithium and move inside under the passenger-side seat. I am following a lot of the information you all have provided here, which has been extremely helpful so far. Everything makes sense.
I can separate the solar connections from those going to the battery disconnect switch, and I know what inline fuses are.
My question is, on the factory battery connection that eventually goes to WFCO, one additional negative wire is crimped (same lug) with the primary negative wire on the battery terminal. I assume it may go to the junction on the trailer frame, but I'm unsure. Does anyone know?
I am just thinking about how this may affect moving the battery.
cheers,
Kevin
Everything from the front tub goes through the trailer junction box on the frame and then to the inside of the TAB (at least in my '21). The negative circuit (wire) from the front tub goes to junction box #7 terminal, then from there to the negative bus bar besides the WFCO. The positive battery circuit (wire) from the front tub goes to junction box #6 terminal, then inside to the WFCO battery wire (also #6).
I also moved my batteries inside w/o cutting any holes for wires. You can splice into the the WFCO battery #6 wire. Ask if you need more details.
Southern Maryland
SOLVED! It is indeed for the Alde. Here are the three wires coming in (second pic of wires from under wet bath area, my thumb on the three). The positive is from the junction box The negative two crimped wires at the battery are free from each other coming into trailer. You can see the one smaller cable running to the ALDE (loose in the ALDE pic). I'll attach it to a new negative bus bar from the new inside battery.
I suspect this is important for anyone changing batteries to inside. Make sure to look for the second negative.
All the rest of what you said, Yoshi, is correct on mine. I've been following your prior work. Thanks for helping the rest of us figure this out.
That same white wire (from the Alde) in my '21 goes to the negative bus bar behind the WFCO..which makes sense to me. So I'm clear, are you saying your white wire (from the Alde) leads out to underwet bath to the junction box and to the battery? If so (but maybe I'm not clear on what your saying)..why would they do that?
Southern Maryland
Edited:I found this old discussion:
https://tab-rv.vanillacommunity.com/discussion/5813/running-a-ground-from-the-alde-to-the-battery
In the thread, Alde recommended a direct connect to the battery. This was from Alde:
Southern Maryland
2023 T@B 320 S Boondock
Just for my curiosity..double check where the second pigtailed negative in the front box leads to. Doesn’t go to a solar connection? A second battery? Do you have a helper who can assist in running a continuity check on what you think are both ends to confirm the other end. Maybe email Nucamp Tech support?
Good luck..RV wiring is often like the Wild West
Southern Maryland
2024 NuCamp T@B 400 BD, Charcoal / White
Adding an Alde specific ground wire was a 'recommended fix' for blown fuses on the 3010 model Alde.
I'm very confused why nüCamp is installing an extra ground connection on the newer 3020 Alde units. My 2018 has the 3020 and NO extra ground wire - - - and I've never had an Alde Fuse failure.
I question the "wire tracing method used".
Most likely my WAG would be the extra ground wire is related to the Solar Panels & Controller.
Tracing method is - grab the white wire on the battery neg. and slide your hand along said white wire directly to the Alde. The wire is literally only a few feet long.
"The 12-volt supply to the boiler must be routed directly from the battery via the vehicle’s main switch"
The 16 AWG wire from the Alde is the only 16 AWG I see in the tub. This also fits BOatguy's direct connection in the 400. I will make sure to verify before doing anything.
The solar wires on my 320 enter the trailer completely separate from junction box items—at a different entry point. It is straightforward to see that this is not related to solar--that I am 100% sure about. I highly doubt they would attempt to use 16 AWG for the solar controller connections.
Finally, I've done something pretty extraordinary to understand this better. I've emailed NuCamp. lol.
The white wire is NOT (at least in this instance) and “extra” ground wire. It simply is the negative side of the 12v system which operates the Alde as @kevmon mentions from the install manual.
Here is a photo where you can see both the red (positive) and white (negative) wires that are connected to the 12v plug to provide power to the Alde.
@Yoshi_TAB @elbolillo @MuttonChops @B0atguy @Sharon_is_SAM @bjn2 @ScottG
My email: I have a question about the Alde. I see a 16 AWG negative cable running from Alde and going under the wet bath. I also see a 16 AWG cable on the negative battery terminal crimped to the main battery's negative connection. Is the Alde wired all the way to the battery (-) directly?
My email: Just to clarify, do you mean grounding for the Alde system? It's a smaller second cable crimped to the primary one on the negative terminal and appears to match the AWG of the ground coming off the Alde. The Alde installation manual suggests that there should be a direct connection to the battery's negative terminal to avoid voltage fluctuations. I know of one person with a Tab 400 that can see the direct connection from Alde to the battery because their batteries are inside. I want to verify this for the 320.
For all the other 12v runs in the Tabs both the positives go to the converter and the negatives (or grounds) go to the negative DC bus bar behind the converter.
