@ScottG and I have been having a pump discussion in another thread, but I have a question for those not following it. There's a by-pass adjustment on the Shurflo pump that I believe will control how much water can be drawn after switching off the pump. Currently I can get almost a gallon.
@ScottG gets none. What is your experience?
I took that to mean that it allows water pressure built up after the pump to start bleeding back to the fresh water tank once the set pressure is reached. It should be set "at least 10 psi higher than the pump shut off pressure." If set too low the pump will not shut off, but wonder if any condition could allow it to reduce water pressure after the pump is shut off.
