'23 Toyota Tacoma "Smart" Alternator defeating DC-DC Converter
Maxcamp
Member Posts: 352
Looking for Victron settings from someone who has a comparable setup please.
After a lot of work wiring up a DC-DC converter and 6awg wire and fuses from truck to camper, it looked good in initial testing. First day on road proved we're getting NO charging. The crazily variable output of the Tacoma 'Smart' Alternator cycles within seconds from 13.6/13.7 v down to 5-6v and possibly to zero.
using: www.amazon.com/Orion-Tr-12-30A-Isolated-Charger-Booster/dp/B07ZKG396Y
40A inline fuses between truck battery and Anderson connectors to Tab DC-DC Charger. (Yes Victron manual calls for 60A but my battery terminal fuses are also 40A.)
Hours of testing today at idle and at 2500RPM elicited this cycling of truck output below acceptable voltage ranges for the DC charger.
Truck output averages 13.8 to 13.9v with engine running; 13.1v engine off.
Victron is set to re-start charging at 13.6v.
Victron came set to stop charging below a 13.8v threshold, lowered it to various settings at 13.2, 12, or even 5.
Below 12v it just blows the 40a inline fuse as it is milking the truck battery.
Victron putting out 23-9-17-15-12-6-0 amps output on the Victron Monitor as fast as you can read. Stays zero.... then maybe a minute later repeats cycle. Voltmeter on truck input to Victron reads 13.3-13.4v input with a fixed voltmeter. An auto-ranging voltmeter cannot settle down but seems to indicate voltage keeps cycling to 5-6v or even zero very briefly. This is the Smart Alternator at work?
Looking for Victron settings from someone who specifically has overcome this Smart Alternator issue.
Alternatively, someone who has successfully replaced such an Alternator with no-name or high output alternator.
It has been suggested the Alternator is not the issue but the Tacoma ECU (computer) regulates this cycling.
Have you tried turning the headlights on? I've heard that kicks the alternator into high output mode.Rich2019 T@b 400
That does not sound right. The smart alternator varies its output somewhat gradually (unless Toyota is different from everybody else) and even if the alternator itself drops the voltage to nothing the system should have battery voltage. From how I read your post you wired the trailer charge connection directly to the battery. Compare the voltage at the battery terminals with what you are seeing at the victron input, and if you have some long wire at hand measure the voltage drop between the battery positive and the victron input positive, then do the same for the negative side.
Truck battery at rest 12.6V. Running at idle or 2500 rpm both 13.9V. Getting 13.9V at rear bumper Anderson terminals and at input to Victron converter. Autoranging meter fluctuates hundredths but these are pretty close.
Amperage at truck negative ground lead with no accessories 12.6Amps; all accessories runing 33.75A. So the Tacoma 130A alternator has lots of capacity available.
Victron input is 13.8V to 13.9V, no detectable voltage loss over the 6awg wiring from truck.
Victron output is *programmed* at 14.4v and reads this when I cut out the Tab battery terminal breakers. When I snap on the Tab battery terminal brakers the output reads the same as the tab battery, roughly 13.3V at moment. I used the Inverter to draw down the battery from 100% to 85% for the purpose of testing DC charging.
20A Victron DC charger behavior continues to cycle between starting to charge and promptly plummeting to zero charging for a minute, then repeating.
if I set the Victron to Engine Shutdown detection ON (the default to keep from draining your auto battery) the Victron high draw is a brief instant of perhaps 22 amps that dwindles down to zero with a few seconds.
If I set the Victron to Engine Shutdown OFF the Victron high draw is a brief instant of 35 to 37 amps that dwindles down wotihin a few seconds. After two or three cycles this pops the 40A engine compartment resettable breaker.
Again, if someone with a 3rd gen. 2016 through 2024 Tacoma that should have the same alternator, and has a Victron DC charger, can pass along their Victron settings I'd be grateful. Here is what I have at the moment:
2021 T@B 320S Boondock/ 2012 Tacoma 4 cylinder truck / 2023 Tacoma 6 cyl. truck0 -
I realize you're looking for a simple setting to solve the issue but there are two things working against you:The smart alternator drops the voltage down to 12.5V if the PCM deems the battery fully charged. You would have to set the lockout lower than that to avoid it kicking in while driving but that means the battery would be discharged when the engine is off until the lockout voltage is reached. The correct fix would be to put a relay into the power feed for the rear connector which is controlled by a wire from an ignition power source.The basic function of a DC-DC converter is to use lower voltage and higher current to generate a higher voltage with a lower current. Some back of the napkin math with your max output voltage of 14.4V and worst case 12.5V on the input side and the 87% efficiency of the converter comes out to ~1.3 times higher current on the input side vs the output side, 38-39A. Basic rule for breakers is 125% of continuous load so the breaker should be at least 50A, better the recommended 60A.0
Look into what the folks with REDARC dc-dc are doing. It’s the “go to” for Tacoma folks. Good info from them.2022 TAB 400 Boondock, 2019 Toyota Tacoma Sport 4x4
Odessa, Fl.
I don't think it's your alternator. I ran power from the battery through a heavy duty on/off and fuse to a plug on the back bumper. DC-DC is mounted inside the front tub of our 400. Connect seven pin, connect Anderson/Harris plugs, start vehicle, turn on head lights, check power light on DC-DC is on. For us, we have to have the head lights on.
Haven 220
2026 Ford F150 Tremor 5.0
Niceville, Florida
I finally threw in the towel on Engine shutdown detection (Esd) with my standard TV (2023 Toyota Sienna 4WD Hybrid) and Victron XS DC-DC charger. I instead installed an ignition controlled relay in the TV to shut off the AUX 12 when the engine is off.With the Esd enabled I would only see charging when climbing a hill with the gas engine running at high RPM, which is exactly not what I want.
So now I disable Esd. I also disable the charger when climbing long hills.In addition I set the maximum input current from the TV to the trailer at 10A since Toyota does not specify the ampacity of the hybrid DC-DC converter.
If someone figures out how to make Esd work with a hybrid computer system, I'm all for it.1 -
Hear you.bobctwin said:
. . . finally threw in the towel on Engine shutdown detection
. . . installed an ignition controlled relay in the TV to shut off the AUX 12
GM stopped installing 7-Pin +12VDC relays some years ago.
On my yr-2017 I added a relay.
Another example of 'Marketing' Towing Package vs. real-world 'what you get'; . . .
Well the Tacoma smart alternator had me skunked for two years! How to overcome it dropping output to near 10 volts and keep a DC converter working?
In a final fit of exasperation disassembled setup and made mockup at truck hood with very short cables to see if cable length was the insuperable issue. 6awg is largest the converter accepts. All good, no cut outs to zero.
Turns out the waterproof breaker installed under truck hood had excessive resistance. Replacing with flat LNL fuse corrected the excessive voltage drop.
Set the Orion DC DC converter low parameters for engine off at 10.0v and all is well now. Charging is constant at close to rated 30 amps so I'm happy.
(Amperage ramps down as tab batteries progress from Bulk to Float.)
Readings: Truck puts out 13.3v at battery but Victron says getting only 11.4v input after 30 feet of cable and multiple connections. Output should be 14.4v but victron reads 13.7v.
Now we can quickly recover from 25amp nightly inverter drawdown of our batteries (microwave, med device)
2021 T@B 320S Boondock/ 2012 Tacoma 4 cylinder truck / 2023 Tacoma 6 cyl. truck1
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 920 Tips & Tricks
