Inner jack tube bottom rust - Repair? Replace?
Emy
Emy Member Posts: 27
Looking for suggestions. The lock pin hole for the wheel is no longer a hole. Help and thanks!
northern ohio . 2015 320s . jeep wrangler
  • Binghi
    Binghi Member Posts: 417
    I would replace it. Looks fully rusted out at the bottom.
  • AnOldUR
    AnOldUR Member Posts: 1,763
    Cut it off above the corrosion. An inch or so shorter won't cause any problems.
  • ChrisK
    ChrisK Member Posts: 282
    That's actually a great idea since these jacks are a hair too long anyways. Also, treat it with a rust inhibitor after cutting it.
    2014 T@b S Max AKA T@dpole
  • Emy
    Thanks!
