We too found this early in ownership. 1. Lots of white shavings from cutting and or shaving cut Pex tubing. Nucamp failure to follow manufacturer protocols and required system flushing. 2. Gummy white residue after one thankfully short Alde use with RV antifreeze in it. Long since rectified. 3. Microcracking of clear plastic housing. Whether oxidation or pressure are the cause, this is well documented in the forum to reduce pressure retention and pump prime. Its cheap to replace the clear plastic filter housing and reduce pressure loss.
No, just clean the filter. Maxcamp is referring to what can happen if the plastic filter bowl is cracked. It can prevent adequate pressure in the pump line due to air entrainment and that will prevent the pump from priming. When you run your pump after replacing the filter it may require more time to overcome the pressure loss created with interrupting the plumbing line.
@Ghannan my filter has the same milky coloring!! Just discovered recently. It does not clean off. It's not slimy or anything, it's like the plastic has discolored. My fingernail didn't scrape it off either. I even tried vinegar but no change, so I screwed it back on. No problems with water pump.
Debbie in Oregon Sold 2023 Tab 400 Sold 2018 T@B 320S
Sometimes I wonder if Nucamp changes build components just to keep in practice. Always a forensic investigation to find out what you bought compared to others' documentation.
Sold 2023 Tab 400
Sold 2018 T@B 320S
