Hitching and Towing Help
ADMIN NOTES
Description: Video and other how-to resources to assist owners with common problems encountered when hitching and towing their trailers.
Created by:
Various
Posted by: Various
Disclaimer:
 Resources provided by members are not necessarily endorsed nor approved by nüCamp. Models differ and configurations are subject to change at any time. Use at your own discretion.
  • Michigan_Mike
    edited January 2018
    Tips for Controlling Trailer Sway
    These videos contain some useful/helpful tips for controlling trailer sway.  You must have at least 10-15% of the trailer's total weight on the tongue of the trailer (over the axle and to the front, between the trailer and tow vehicle) to eliminate any trailer sway.
    An example of trailer sway below....
  • Michigan_Mike
    edited January 2018
    How to back up a trailer
    This is a good video and it really does work!
    https://youtu.be/RLtfrBWzNCw
  • Verna
    Verna Member Posts: 6,876
    edited January 2018
    Coupling issues/Hitching issues/Couple stuck on the ball/Stuck coupler
    Different descriptions for being unable to unhitch from your T@B. Here's a how-to YouTube video compliments of @TabberJon and his research:
    The manual jack is easy to turn. An electric jack would not alleviate a stuck coupler.
    Watch this video for reasons why an Atwood coupler will stick (on purpose) and what to do if that happens: https://www.youtube.com/watch?v=Zq3f8b37laQ
    The coupler might also be stiff due to no lubrication in which case the gentle pry method under the front lip of the coupler works fine.
    ScottG Administrator Posts: 5,696
    edited October 2018
    Hitching and Towing Tutorial
    Description: Keep the Trailer Connected to the Truck--Understanding the "Hitch" System is a comprehensive go-to reference for understanding and properly using hitch systems.
    Created by: Purdue University Extension
    Posted by: N/A
    Disclaimer: Resources provided by members are not necessarily endorsed nor approved by nüCamp. Models differ and configurations are subject to change at any time. Use at your own discretion.
    edited June 2024
    Trailer Hitch Couplers
    Description: Video of hitch coupler styles.
    Created by: Etrailer
