Where to get plastic "trim"/"weather striping"
mickietucs
Member Posts: 720
The black plastic that goes around the door came out completely and I'd like to replace it. The rv place where I store it had some but it's way too stiff and I think a little too wide to easily go in the rail. Anyone purchase a replacement and if so do you have details on size I need to get? Thank you.
I did a search on the forum for “weather strip” and found this thread. Check out the entry by BillK 2022. The product is called Trim Loc and is available on Amazon.
https://tab-rv.vanillacommunity.com/discussion/14303/2008-t-b-trim-seal-replacement
Kootenays, British Columbia
2015 Little Guy T@b, TV - 15 Toyota Highlander
"Good friends beware! the only life we knows Flies from us like an arrow from the bow, the Caravan of life is moving by, Quick! to your places in the passing show.” -
I know it as screw cover molding.Kootenays, British Columbia
Thanks to all for the information - so appreciate this forum!Michele, Tucson, AZ. TV - '13 F150 & '16 T@Bitha special order.
- 919 Introductions
- 74 Teardrop Groups & Links
