I am needing to add shims of some kind to several striker plates to raise them so window latches will click into the slots & hold window closed properly. What would work for shims and then will I need slightly longer screws to tighten down the striker plates?
2018 Tab 400
0 ·
Montana USA
https://www.amazon.com/CREGEAR-Plastic-Sheet-Inch-Thick/dp/B0CMZZGXPX
Montana USA
"Just Enough"
2021 T@B 320s Boondock "Pull-T@B"
2024 Nissan frontier Pro-4X
South-Central Indiana
Regarding the double spacing: it has been a problem with the Vanilla platform not playing nice with certain browsers, devices?.. @Scottg knows more. I will see if I can fix it. (Edit - I tried. I can’t tell if it changed anything here on my iPad. If not, try using a single line format like my signature.)
You guys fixed the signature block. I typically use Firefox and it appears good now.... Many Thanks!!!!
I was a programmer and EE for many years. I am now retired and don't want to program anymore... Now, I just use the software as it comes....
I took more pictures of the front window latches.
As far as the mounts to the window, It doesn't appear they can be adjusted other than shims. I submitted a service request to NuCamp and I guess we will sort it out there...
Thanks to all!!
I have found myriad uses for 1/8 inch x12x12 ABS sheet material to make up shims, backplates, flip down l.e.d. nighttime covers, and more.
