Hi all,
We have a 2024 Tab 400 and the shower drain is leaking. At first it was leaking at the fitting that screws on to the shower drain (red arrows) and I thought I fixed that by tightening up the screw on fitting (yellow arrow). But now it is leaking in the area between the screw on fitting and the flange nut above that fitting. Water is seeping out in the area of the blue arrow.
I took the assembly apart and was surprised to see no gasket between the drain assembly and the flange (green arrow) that screws on to the drain. I did not take a picture of it apart but the flange nut is the big item that screws on to the drain assembly itself just above the blue arrow in the pic:
This is the third plumbing issue I have come across in the few weeks we have owned the camper. When I email nuCamp support that have been pretty fast in replying but I am getting tired of finding problems with a brand new camper. We had a 320 before this and had zero issues so I am surprised at this experience.
Has anyone had this area apart, did you have a gasket between the flange nut and the drain assembly? I know that is how it is done in household plumbing.
Thanks,
j
