Dog sets off CO2 detector
I have an Aussie who loves to lay against the CO2 detector (cause I have the a/c vent pointed downward).  Unfortunately, he routinely sets off the CO2 detector.  Not an issue if we’re awake but when it happens at 0100 it’s a real bummer.  If I remember I set a pair of shoes on top of each other in front of the detector.  Looking for something with a bit more class.  My wife thought a small mesh basket like a strainer for noodles or something similar.  Mesh allows free air flow but with a 1/2 to 1 inch stand off it would prevent the Aussie from laying against it.  I would attach it with Velcro so it was easy to remove when I needed to replace the batteries, system checks, etc.  I’m tempted to ask my son to design something in CAD and print it on his 3D but before that, thought I would hit the forums and see if anyone has experienced the same issue and had a solution.
Haven 220
2026 Ford F150 Tremor 5.0
Niceville, Florida
  • rfuss928
    rfuss928 Member Posts: 1,197
    There are lots of sizes and shapes of RV furnace vent screens.  Maybe something like these could work...
    Sponsored Ad - Eazy2hD 4 Pack Flying Insect Screen for RV Refrigerator Vents RV Furnace Vent CoverRV Furnace Bug Screen
    https://www.amazon.com/s?k=rv+furnace+vent+screen&crid=BZ7O4ESATF6G&sprefix=rv+furnace+,aps,419&ref=nb_sb_ss_ts-doa-p_1_11
  • Grumpy_G
    Grumpy_G Member Posts: 789
    Actually it's a carbon monoxide (CO) and propane detector and it also reacts to methane gas, a.k.a dog farts. No kidding, google it. :)
  • fstop32
    fstop32 Member Posts: 391
    @Grumpy_G you stole my thunder!!  =)  But you are correct on both counts, what that detector does and the exhaust gases from a dog.
  • WayneW
    WayneW Member Posts: 263
    Our black lab was doing the same thing - laying against the detector and setting it off.  It makes quite a racket!
    I solved that by mounting a short piece of baltic birch plywood just below the detector with 2 screws from inside the bench storage area.  I didn't know if this was going to be enough to prevent the detector from going off but it has been working good for a year now with no accidental discharges (except from the dog's rear end of course).  Inobtrusive and I can easily get to the detector if need be.  The black tape, complete with dog hair, is to cut down on the green light that is a bit too bright at night.
    2021 320S BD
    2017 F-150
    Coeur d'Alene, Idaho
