I have a 2022 Tab 320 boondock. The Alde system will not turn on.
I've reset all the breakers. I replaced the 30 amp fuse. I've removed and repluged all the wires. I've check the 75amp [purple] fuse. The multi purpose fuse includes the lights and they are working. I am not sure what else to do.
0 ·
https://tab-rv.vanillacommunity.com/discussion/18747/alde-not-turning-on#latest
2024 Kia EV9
thanks for the input. We have the Alde 3010 compact unit and have checked for loose wires.
2024 Kia EV9
855-558-7862. M-F 8 am - 5 pm. You can also leave a voicemail for the Service Department.
While I don't have any additional advice on "things to check"
These three reference items might help complete your troubleshooting/investigation.
First: Your 2020 320 has the Alde 3020HE system. From a user standpoint the main
differences in a 3010 and 3020 are
+ - + 3020 has one green case 3.5A fuse on the control board
+ - + 3020 only shipped with the digital touchscreen display panel
+ - + 3020 has a high altitude Control Panel mode
Second: Attached PDF has a simple (homemade) diagram showing how the 120VAC
and 12VDC are connected to the trailer with Fuse locations.
Sometimes a diagram helps.
Third: A video link to an Alde troubleshooting guide showing how to do basic
tests to confirm the Adle is getting 12VDC from the trailer. Use of a DCV Meter
(multi-meter) is shown.
Alde Dead Control Panel
