Want to replace heavy table with Lagun-- help please
I have a 2018 Tab 400-- which has the really heavy table & I can't deal with it.  Have read old posts--Verna's post & Geo Montana post on putting in a Laguna table & the support structure added to the panel that covers Alde stuff.
I removed the screws on each side near the floor of that panel/ Alde cover between the front seats but the "cover" is still solid & I can't tip it forward to peek behind that front panel to see where wires & other stuff is.  Where are the other screws to take out so that cover will tilt forward?
2018 Tab 400
    Bump— anyone??
    2018 Tab 400
  • HoriganHorigan Member Posts: 767
    When I did my conversion I didn't remove that panel.  I just screwed a block of wood to it, then built a box around it that I mounted the Lagun mount to.  The box follows the contour of the floor and when I fastened it to the block (hidden) I made sure it was pressed down on the floor so the floor takes the vertical load.  I'm not able to find it, but I used a tool box wood top from Home Depot to build the box and to use as the top.
    Rich
    2019 T@b 400
    Bellingham WA
    Thanks so much for the info & pics!  You do beautiful work!  Are you using the lagun table as the bed platform for use as a bed in that area?  If so did you put the hook attachments on the lagun table from the heavy original table?
    2018 Tab 400
    edited September 2024
    Thank you!  We don't use that area as a bed, so I haven't set up the table to support the mattress section.  If I were to, I would just lay the table on the support structure around the outlet, with some framing to get the height right, and possibly add a swing down leg to the table, similar to the original table.  Here's a view from the bottom.  The table mount is pretty offset to the front, hence why the support box on the floor comes out so far aft.
    Rich
    2019 T@b 400
    Bellingham WA
    Thanks for the pics— I  want to do this!  Another plus is you don’t have that terribly heavy & cumbersome old table.
    2018 Tab 400
  • BlueespyBlueespy Member Posts: 234
    I have a 2019 t@b 400 BDL and wanted to replace the heavy table.  Learned nuCamp put a lighter weight table on later models, so I just bought the new one from them.  Much lighter and easier to move.
    2019 T@B 400 BDL
    2020 Ford F-150 XLT (V-8)
    Niceville, Florida
    Hmmm—-What year was is that they changed?  What was the cost on the new table?
    2018 Tab 400
    edited October 2024
    My sincere apologizes, I did not see your question.  I'm not sure when the new table was offered, but I think I purchased ours in Augu 2020 and the cost was $135.30.  There is a slight size difference according to my wife - she says it's a bit narrower and shorter, meaning doesn't still as far out into the camper as the old.  It is DEFINITELY lighter.
    2019 T@B 400 BDL
    Niceville, Florida
