Class II vs Class III Hitch for Tab
HobieHobie Member Posts: 12
Nucamp's website states in the Q&A page below that a Class III hitch is needed for towing a Tab. Some factory hitches are Class II and rated for 3500 lbs, which should be adequate for a 2017 Tab 320. Is there any reason a 1-1/4" Class II receiver and ball mount cannot be used with a 2" ball?
What Type of Hitch do I Need to Tow the Trailers
Modified on: Tue, 15 Feb, 2022 at 10:19 AM
For the TAG, TAB, and TAB400 you need a class 3 hitch with a 2" ball.
  • Grumpy_GGrumpy_G Member Posts: 673
    Class II hitches are limited to 350 lbs tongue weight. With a 320 there is a good chance to stay under that number even fully loaded unless there is something heavy mounted to the tongue (e.g. bike rack with e-bikes). The 400 is listed at 328 lbs dry so it will exceed the 350 lbs limit when loaded.
    Found this from Curt.  Possible the shank opening may be too small.  But, you may get lucky!
  • HobieHobie Member Posts: 12
    Thanks, Sharon. There is no problem with assembling the Class II ball mount and 2" ball. Etrailer.com even shows a pre-assembled unit. What I am wondering is why Nucamp says Class III is required for all Tabs and whether others have had any problems towing Tab 320s with a 1-1/4 inch Class II hitch.
    CURT Trailer Hitch Ball Mount - C45147
    • Fixed Ball Mount
    • Fits 1-1/4 Inch Hitch
    • Drop - 1 Inch
    • Rise - 0 Inch
    • 2 Inch Ball
    • One Ball
    • 3500 lbs GTW
    • Class II
    • CURT
    • Steel Shank - Gloss Black
    • Steel Ball
    This convenient starter kit puts you on the towing fast track. Includes a 9-3/4" long powder coated ball mount with a 3/4" rise and a 1-1/4" drop; a pre-torqued 2" hitch ball; and a pin and clip.
  • elbolilloelbolillo Member Posts: 537
    More than likely they are building in some headroom on the specs.
    Thanks. Just got a response from Nucamp:
    I spoke with my tech and we would not have an issue with this as the towing capacity is high enough to cover the weight of the camper.
