new tongue jack for tailgate clearance
I installed this jack yesterday. It has flexible design in that you can remove it all together or drop the outer sleave to the ground and lower the handle portion to clear the tailgate in the open position. It took a small amount of grinding to enlarge the pass-through spot on the existing plate. once that was done the slots on the jack needed a little enlarging as well. The I was able to use the existing bolts. $89 The Ultimate Trailer Jack 2,000 lb. Lift Capacity Trailer Jack, RDJ-2K at Tractor Supply Co.
