I just installed two 100A Deep Cell Batteries. Afterwards I was checking my Victron SmartShunt and it isn't powering up nor coming up as a device. (The power on blue light doesn't come up). I was careful to replicate the wiring that I had on before and which has
worked great for years. I checked the Victron fuse and it looks good. Any ideas are appreciated. I'm going to dinner and will check for helpful replies when I get home.
A couple of thoughts, if/when you remove the fuse, check for 12V on the incoming voltage side of the fuse to see if you have voltage up to that point. Same for the stub that goes into the shunt. Check for voltage there. I once had a bad connector that goes into the shunt. It failed from being flexed or bent too many times.
Southern Maryland
