After returning from a trip with my 2022 Tab 320CS, I opened the usual low point, heater, and fresh water drains. There was not much freshwater left in the tank, and while some did come out of the exit, I noticed water flowing from a strange location near the freshwater tank drain valve. It flowed down under the external floor of the camper.
I have never seen this before. Is it a symptom of a bigger problem? Have any of you seen this before?
Thank you for any tips and suggestions.
Normally, when I drain, water only comes out at this point, as expected. This latest time, there was minimal water coming out, and some dripping at the odd area indicated by the water in the photo. The tank is nearly empty, hence the limited amount coming out of the proper drain, but I had never before seen water in the areas shown.
If so and water is not creeping backwards along the outside of it you may have a fitting leak. Perhaps you can remove some of the coroplast fastening screws (50% may shear or have been sheared by Nucamp! Requiring vise grips and curses...) and peer inside while draining.
On my 2021 320s the threaded tank outlet threading is oversized (loose) and Nucamp stuffed plumbing putty into the threads... which leaked.
I replumbed the entire drain run.
https://tab-rv.vanillacommunity.com/discussion/comment/202413/#Comment_202413
photo four shows tank connection.
I am hoping it is not a fitting leak.
An update. When I first drained and saw the dribbling / leak symptoms, I did not have the trailer tilted toward the back and corner as I usually do. This is important because my driveway at home is a slight grade.
I jacked it up and tilted as usual, and opened the drain again, and far more water came out of the fresh water drain discharge tube, in a flow as usual, and no dribbling on the underside as shown in my original photos above.
I think that the water was "just" dribbling out of the exit port, and trickling back in and under, and down the underside.
I will post back here if I see the "leaky" symptom again. Otherwise, lesson learned to be sure the trailer is tilted well before draining.
