We just got back from Acadia Blackwoods with our 2024 NUCAMP 320S. We were running off of solar. we had 100 percent battery when we unhooked. We were GTG the first two nights then something went haywire the second morning. Our I phones could not connect consistently to the Victron and when it did, it pulled up a 'REDFERD SHUNT" and a "REDFERD SOLAR". Our SHUNT and SOLAR were not receiving predictably into the I PHONE. CAN someone intentionally stop the VICTRON from being received from a paired device?
We had no power the third night with 39 degrees outside so we used a portable gas heater for a few minutes and awakened to an inside temperature of 63. We had electrical hookup en route and everything seem to reset itself and now home with no issues.
As asked above, can someone intentionally stop the pairing from functioning properly? If so, how do I prevent? How did VICTRON APP pull up the "REDFERD SHUNT" and "REDFERD SOLAR"?
Thanks for your constructive comments.
0 ·
2024 Kia EV9
What is your battery setup? Capacity? You said you had “electrical hookup en route? What does that mean?
Victron appears to be functioning properly now.
https://www.amazon.com/gp/product/B07TM8VWX8/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
You may find a much more versatile multimeter useful for many other troubleshooting tasks.
You will need to monitor your usage to determine what percentage of battery you are utilizing per day. If you are in a sunny site then your solar should help.
