Low Rolling Resistance Tires
CatDaddyCatDaddy Member Posts: 86
edited October 2024 in Trailer & Towing
I'm planning to tow my 320S with my 2023 VW ID.4 AWD electric car. To maximize the range, I am looking at tires with lower rolling resistance than the Rainer Apex ST tires (ST235/75R15) tires that are on the 2022 320S Boondock I'm purchasing. The Rainer Apex tires are off-road tires that probably have a rather high rolling resistance.
Here are a few options I've found:
Greenball Transmaster EV: Only comes in ST225/75R15 or ST235/75R15. I would probably go with the ST225/75R15 which will lower the trailer slightly but reduce the tire weight by ~4lbs each. I've never heard of Greenball tires but apparently Costco sells them.
Goodyear Endurance: ST225/75R15 frequently recommended on this forum.
Kumho Crugen HT51: LT235/75/R15
Michelin Defender LTX M/S: LT235/75R15 Discount Tire says this size has been discontinued but Michelin says it's available.
Given that the new 320S Boondocks are coming with Goodyear Wrangler Trailrunner SL rated passenger tires, I am thinking that I don't need to get ST or LT rated tires.
The Greenball Transmaster EV tires are the only tires I've found that are specifically designed for EVs and low rolling resistance.  They're also really cheap, but I'm not one to cheap out on tires as I've found you get what you pay for.
Does anybody have any thoughts on this?
2022 NuCamp T@B 320S Boondock
2023 Volkswagen ID.4 Pro S Plus AWD
  • manyman297manyman297 Member Posts: 1,385
    I went with Hankook Vantra trailer tires. They were made to compete with Goodyear Endurance in terms of specs but obviously much less expensive. We’ve put a few thousand miles on them and they seem great. Link is here:
    https://a.co/d/dQp6nXZ
    2021 400 BD
    2020 Tacoma TRD Off-Road
  • CatDaddyCatDaddy Member Posts: 86
    edited October 2024
    Thanks, I didn't see that option in my search. Did you notice any improvement on your gas mileage after you switched? I'm trying to find tires with lower rolling resistance.
  • MuttonChopsMuttonChops Member Posts: 1,786
    EV designed tires are very 'hard' to handle the high loads and braking stress . . . not needed on trailer, any street thread (not A/T) with the correct load rating and extra strong side walls [ST or LT type] will have lower rolling resistance than the 'stock A/T' tire and softer ride then an EV tire.
    That said would be surprised if trailer tire impacts Miles per Charge more than a small bit when compared to the large impact of trailer weight wind resistance.
    @CatDaddy Not really if I’m being honest. The biggest issue with our 400 is just the shape of it and the turbulence caused between the truck bed and front of the camper.
    But the tires seem fine so far. Time will tell. We don’t put a ton of miles on our camper so the endurance seemed like overkill.
    2021 400 BD
  • MickerlyMickerly Member Posts: 450
    You may want to look at Carlisle tires. I think they distribute through SAMS. There are a great highway trailer tire.
    I went with Hercules Strong Guard ST (Hercules is a division of Cooper Tires). They are load range D, so I run them at 58psi to give them a little flex. You will have to find a place that caters to the agricultural community to find Hercules.
    Have the installer balance the tires. Yes, this is not typical for trailer tires. It makes a significant difference.
    2018 320CS-S
    "Just Enough"
    We purchased our Carlisle tires through Walmart online. We had them delivered to our local store. For an additional fee they were mounted and balanced on our rims. We've had no problems through more than 7500 miles they've been on our Tab.
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 9,931
    We replaced our tires with Carlisle’s on our CSS.  No problems.
    rfuss928 said:
    Some info from and a link to a Consumer Reports article on the subject...
    I looked at that review CR did. Unfortunately, most of those tires are not available in the size I need. I appreciate the help!
    The tires on both of my EVs ride better than the tires I had on my 2005 Altima back in the day, but I agree that EV tires are designed to handle heavier loads associated with EVs.
    The Greenball Transmaster EV tires are ST rated with load rating of E which is going to really stiff; even stiffer than the D rated Rainer Apex tires currently on the trailer.
    I'm on the fence about whether I really need ST or LT rated tires. The current 320S Boondocks are coming with Goodyear Wrangler Trailrunner AT tires which appear to be standard passenger tires. They are SL (Standard Load) tires with a load index of 105S. I'm not a tire expert, but they are rated as if they're standard passenger tires.  For this reason, I am skeptical of the need for ST or LT rated tires.  I'm always open to be being educated.
    I agree that the lower rolling resistance tires will not have a huge impact on range. Some of the tire tests I've read suggest that getting a 10% increase is about the maximum.  I think the rolling resistance of the Rainer Apex off-road tires is probably quite high compared to a highway tire, so maybe I could get 5-8% more range? That's a complete guess. Part of me wants to try the Greenball Transmaster EV tires just to find out. They are less than $100 each so the experiment wouldn't be crazy expensive.
    My understanding is that ST rated tires tend to be E load range not so much for travel but for when the camper is parked. The thicker sidewall provides more support and less sidewall flex. For a small camper Iike the 320 I think load index is less a factor since any SL tire should be able to handle the weight.
    2021 400 BD
  • d_vd_v Member Posts: 42
    edited October 2024
    I went with both a smaller trailer tire and wheel. Lower rolling resistance, less weight, lower camper height. I wish I had a good A/B test on consumption difference but I don’t. With the smaller ones I’m getting 620ish wh/mi at 53mph towing with a Model Y.
    Tires are ST205/75/14 Goodyear endurance, load D.
    I just got home from picking up my new to me 2022 TAB 320S Boondock in Medford, Oregon. I towed it up I-5 today. I'm still compiling my data, but it looks like I averaged something like 555 wh/mile on the trip. A bit more in the hills and a bit less on the flats. The trailer has ST235/75/R15 Load D Rainer Apex tires. My TV is a 2023 VW ID.4 AWD.
    I was surprised to find that speed didn't make much difference, but the hills really did. I'm wondering if I need to tweek the settings on my brake controller.
  • SLJSLJ Member Posts: 608
    edited October 2024
    Get a smaller tire. It will reduce the T@Bs height and put more of the TAB's front surface area behind the tow vehicle. That will make more of a difference in gas mileage than a tires rolling resistance. It's all about surface area once you're up to highway speed. Hills and weight are the other consideration.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2023 Ford Maverick XLT
    The Finger Lakes of New York
  • ColleenD2ColleenD2 Member Posts: 529
    Tire question while I have you all. I am having my Goodyear endurance put on the camper today but I'm curious about tire pressure. Do we follow the pressure on the tire? Of course on the label of the tab it says 50 but that's because they expect the Chinese tires that are on there. The endurance says 80. I want to be safe.
    edited October 2024
    To do it correctly you need to weigh the tires/axle when hooked up (can do it on a CAT scale at a truck stop) and then divide the axle weight by 2 to get the weight of the load on each tire. Then go to Goodyear's web site and check the chart for that tire/size. It will tell you the required pressure for your weight. The label on the T@B is only for the original tires from the factory.
    The data suggests that wind resistance isn't as strong a factor in range as I thought. When going 65 mph on the highway, I was getting about 1.8 miles/kWh with the trailer.  Dropping it to 60 mph dropped the power consumption to 1.9 miles/kWh.  I was getting about 2.0 to 2.1 miles/kWh around town at 35-40 mph.
    Without the trailer, I was getting around 3.3 miles/kWh on the highway.
    This suggests to me, that speed isn't as big a factor as I thought, which means that lowering the trailer probably won't help that much with range, but will definitely impact the ground clearance.
    I'm not sure that lower rolling resistance tires will help that much either, which is why I was asking if anybody had any data about it. I wish tire manufacturers published rolling resistance information for all of their tires.
    You can run at the max operating pressure of the tire, which will reduce rolling resistance.  Whether you'd be able to measure it is an open question.  However, running at max pressure does impose a harsher ride for the trailer, so you may experience more vibration related failures over time.  Tires have a pressure vs. load curve, hence the suggestion above to weigh the trailer to determine the load.
    Rich
    2019 T@b 400
    Bellingham WA
  • dlbdlb Member Posts: 154
    Lower pressure in a tire allows it to flex more, softer ride, more heat build up in the side wall, bad for the tire life and increased blow out potential.  I buy the tire I want for the specific vehicle and run them at maximum tire pressure recommended by the tire manufacturer.  If you don’t want to run with 75-80 psi, buy a different tire.
    2021 Tab 400 Boondock
    2020 Audi SQ5
  • BinghiBinghi Member Posts: 366
    No way I’m going to inflate my Goodyear Endurance tires to 80 psi. They run fine at 50 psi and I’m not going to rattle and jar my trailer into oblivion. I’ve never inflated a tire to 80 psi and likely never will.
    I have E-rated tires and run them at 75-80psi and they seem to ride well at that pressure. When parked there is minimal sag in the sidewall.
    2021 400 BD
    Goodyear publishes a tire pressure chart for the Endurance. Look up your tire size and the weight of your trailer, your will get the correct pressure for your application.
    2018 320CS-S
    "Just Enough"
    Mickerly thank you. I checked it out and Goodyear wants us to run at 65 psi on the endurance based on the weight, etc. I really appreciate you thank you
    edited November 2024
    After doing a bunch more research, I'm following up my OP with more information about low rolling resistance tires: I've found a few tires that they claim have lower rolling resistance.
    These are available in ST225/75R15 size. Walmart is selling them for less than $75 each with free shipping. They are made in China, but in general, they get decent reviews. There is one report of tread separation on the Walmart website.
    Available in ST225/75R15 size. Discount Tire is currently selling them for $127 each. Good reviews. They claim their rubber compound offers longer life and lower rolling resistance. Made in Korea.
    Available in ST225/75R15 size. Discount Tire is currently selling them for $130 each. Only rated for speeds up to 62mph (Speed Rating J) which is a deal-killer for me. They claim to have low rolling resistance. Made in China.
    Available in LT235/75R15 (OEM size for Boondocks). Hard to find. Use Nokian product code T432867. www.tires-easy.com sells them for $185 each. These are "light truck" tires, not "special trailer" tires, but given that NuCamp is shipping new trailers with Goodyear Wrangler Trailrunner AT tires that appear to be passenger tires, I don't know why an LT tire is inappropriate.  My 320S is is quite light. Nokian recommends these tires for electric vehicles. They are "All Weather" tires (rated as winter tires) and are specified for all-terrain use. Made in Dayton Tennessee, USA. I've had extremely good experiences with Nokian tires. EDIT: Discount Tire quoted me $160 each on these tires. That is just the tires without mounting and balancing.
    Available in ST225/75R15 size. Discount Tire is currently selling these for $199 each. This appears to be everybody's favorite tire. Probably lower rolling resistance than the Tredit Rainer Apex tires on my 320S BD, but they make no claims about low rolling resistance. It's also not clear how this tire would handle use off-road. Some of the reviews suggest it isn't really sturdy enough for off-road use. YMMV. Made in USA.
    I'm probably going to try the Nokian Output nATs (first choice) or the Hankook Vantra ST01s (second choice). The Nokians are less expensive than the Goodyears, come in the OEM size, claim lower rolling resistance and after rated for off-road use, plus they're made in the USA. BTW, the Outpost nAT is the successor to the Nokian Rotiiva AT tires mentioned elsewhere on this forum.
    I really wish there was hard data available for the rolling resistance. That would make this decision less of a crap shoot.
    Goodyear is an American company, but few of their manufacturing centers are in North America. The company doesn't confirm American manufacturing. You may want to check the country code on the side of the tire to ensure they are really manufactured in the United States.
    The dirt/gravel road consideration is one reason I chose the Hercules Strong Guard tire. Hercules is a division of Cooper tires, an American company. Hercules tires are intended for agricultural use, i.e. combined dirt roads and highway. While most of their tires are manufactured in North America or American provinces, this tire line is manufactured in China.
    Carlisle tire company, also American, has manufactured only trailer tires for over a hundred years. Their tires are very good and reasonably priced. Their Radial trailer tire is intended for highway use, primarily RVs. The tight tread reflects that. Braking on dirt or gravel may not be the best; however, how fast are you driving on the dirt. Their other tires are more for commercial trucks.
    Rolling resistance is a big selling point for car tires right now. Trailer tires not so much. You may not find rolling resistance data for most ST tires. ST tires generally have lower rolling resistance than car or light truck tires. Look for a tight, highway oriented tread pattern. The tires listed above and the Endurance have highway tread patterns.
    2018 320CS-S
    "Just Enough"
