I'm planning to tow my 320S with my 2023 VW ID.4 AWD electric car. To maximize the range, I am looking at tires with lower rolling resistance than the
Rainer Apex ST tires (ST235/75R15) tires that are on the 2022 320S Boondock I'm purchasing. The Rainer Apex tires are off-road tires that probably have a rather high rolling resistance.
Here are a few options I've found:
Greenball Transmaster EV: Only comes in ST225/75R15 or ST235/75R15. I would probably go with the ST225/75R15 which will lower the trailer slightly but reduce the tire weight by ~4lbs each. I've never heard of Greenball tires but apparently Costco sells them.
Given that the new 320S Boondocks are coming with Goodyear Wrangler Trailrunner SL rated passenger tires, I am thinking that I don't need to get ST or LT rated tires.
The Greenball Transmaster EV tires are the only tires I've found that are specifically designed for EVs and low rolling resistance. They're also really cheap, but I'm not one to cheap out on tires as I've found you get what you pay for.
Does anybody have any thoughts on this?
2022 NuCamp T@B 320S Boondock
2023 Volkswagen ID.4 Pro S Plus AWD
https://a.co/d/dQp6nXZ
2020 Tacoma TRD Off-Road
That said would be surprised if trailer tire impacts Miles per Charge more than a small bit when compared to the large impact of trailer weight wind resistance.
Adventures: 58 Nights: 405 Towing Miles 50,180
I went with Hercules Strong Guard ST (Hercules is a division of Cooper Tires). They are load range D, so I run them at 58psi to give them a little flex. You will have to find a place that caters to the agricultural community to find Hercules.
Have the installer balance the tires. Yes, this is not typical for trailer tires. It makes a significant difference.
"Just Enough"
https://www.consumerreports.org/cars/tires/low-rolling-resistance-tires-can-save-you-money-at-pump-a1547901110/
Tires are ST205/75/14 Goodyear endurance, load D.
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
2025 Ford Ranger
2020 Audi SQ5
"Just Enough"
The dirt/gravel road consideration is one reason I chose the Hercules Strong Guard tire. Hercules is a division of Cooper tires, an American company. Hercules tires are intended for agricultural use, i.e. combined dirt roads and highway. While most of their tires are manufactured in North America or American provinces, this tire line is manufactured in China.
Carlisle tire company, also American, has manufactured only trailer tires for over a hundred years. Their tires are very good and reasonably priced. Their Radial trailer tire is intended for highway use, primarily RVs. The tight tread reflects that. Braking on dirt or gravel may not be the best; however, how fast are you driving on the dirt. Their other tires are more for commercial trucks.
Rolling resistance is a big selling point for car tires right now. Trailer tires not so much. You may not find rolling resistance data for most ST tires. ST tires generally have lower rolling resistance than car or light truck tires. Look for a tight, highway oriented tread pattern. The tires listed above and the Endurance have highway tread patterns.
"Just Enough"
