I may be one of the few people on the forum that has factory FLA (flooded lead-acid) batteries and is old enough to have a hygrometer for battery maintenance, so I thought I'd post this:
My 2022 TAB 320S Boondock came with two 6V, US2200 X2 Deep Cycle flooded lead acid batteries. These are the old-fashioned batteries that are not maintenance-free (aka "
VRLA"). That is both a blessing and a curse.
It's a blessing, because one can pop the caps off the cells and use a hygrometer to measure the specific gravity which is directly related to charge level, which is much more accurate than by using the battery voltage. It also allows one to tell how each of the three cells (6V battery) is holding up.
It's a curse because one has to remember to "water" the battery which means adding distilled water to the proper level. This is done by fully charging the battery and then filling with distilled water as described in the
battery manual.
I now feel justified in saving my battery hygrometer for 50 years...
Here's how the specific gravity relates to the state of charge (SOC):
2022 NuCamp T@B 320S Boondock
2023 Volkswagen ID.4 Pro S Plus AWD
I night go on a campaign to reduce the tongue weight on my 320S but it’s hard for me to justify the expense of the lithium setup right now.
We could go back to horse and buggy and kerosene lamps.
All in good fun...
6V times 230Ah = 1380 watts
1380 watts times 2 = 2760 watts
2760 watts divided by 12V = 230Ah
50% of 230Ah = 115Ah
None of that says you won't get a few day of boondocking from 115Ah.
1 300ah Renogy at $850.00 divided by 295ah usable capacity = $2.88 per ah.
The price of Lithium batteries is falling rapidly. Now, many come with built in Bluetooth battery monitors. That reduces cost significantly and makes the installation more simple. I think this is a sign of better battery technology on the horizon.
If you think Lithium will help your situation, then it's a good idea. The prices are not going up, waiting won't hurt. If the switch in battery technology won't gain much for you, then don't waste the money. Lithium is not for everyone no matter how much you play with the numbers.
I'm not against new technology. There are several things with NuCamp products that could benefit from moving to this century. For us, Lithium is not worth the cost because the only benefit is less weight. There is other, less expensive ways to reduce 30lb.
P.S. I have a hygrometer also.
"Just Enough"
"Just Enough"
