A few years ago when hooked up to city water, I saw a slow drip outside right in front of the wheel on the driver's side. An rv repairman re-created the drip and said some fittings had loosened up (he said the water pipes behind the shower wall). He tightened them up and I was good for a few years. Now it's doing it again. I would like to see if I could tighten them but cannot figure out how to open the access panel. Is it on the cabin-side of the rig and if so, where exactly? Is it below the TV (2016 320)? I see some molding but just looking, can't figure out how to take the panel off. I looked under the seating there and didn't see any water on the floor. Will try this myself but need some help in identifying the steps. Thanks!!
0 ·
On TAB 320S with Black Tank Style Wetbath.
Access the inside Shower Pipes via the long narrow panel screwed to the wall to the Left of the Television.
Reference:
