We are planning to order a 2016 T@B Max S in late September, hoping to get it in early April. The local dealer says they will build it any way I want so I'm putting together a list of what I want.
Options from the factory:
- Front window
- The metal platform and propane cover used on the Outback
- Neutral upholstery such as that used on the Outback or Tabitha
- A Maxxair Maxxfan Deluxe with manual opening
- Outside shower option (dog, gear, dishwashing, etc.)
I will also ask the dealer to install a battery cut off switch and a permanent surge protector, and mount the spare tire to the tongue.
Is there ANYTHING else that experienced T@B owners would recommend, either as factory options or as dealer added items?
0 ·
The standard battery is a group 24, I'd have them install a 27 with the appropriate frame to accommodate the larger battery box. Would give you a little extra breathing room.
Also, will the USB outlets charge an iPad? iPad requires 5v at 12mw. I know the USB outlet in my Toyota won't charge my iPad.
My 2015 MaxS has a standard two plug AC (110) outlet and the DC combo over the counter (left side). Also a standard two plug AC and a cigarette lighter plug on the driver's side bench. And finally, two outlets outside on the passenger side.
A cigarette-lighter-type outlet doesn't draw anything when not in use, so we use 12v USB car-type chargers, and plug them in only when needed.
There are some nice small ones that don't protrude at all, and that put out the higher 2.1A power needed for tablets and smartphones. We also have one that's a double USB charger, with high output on one port.
I've always had good luck with Boxwave:
<a rel="nofollow" target="_blank" href="http://www.boxwave.com/samsung-galaxy-s5-travel-chargers/samsung-galaxy-s5-micro-high-current-car-charger-for-galaxy-s5/bwpdd/gwp-zwpg/">single USB: http://www.boxwave.com/samsung-galaxy-s5-travel-chargers/samsung-galaxy-s5-micro-high-current-car-charger-for-galaxy-s5/bwpdd/gwp-zwpg/</a><br><br><a rel="nofollow" target="_blank" href="http://www.boxwave.com/universal-dual-micro-high-current-car-charger/bwpd/wkv/">double USB: http://www.boxwave.com/universal-dual-micro-high-current-car-charger/bwpd/wkv/</a>I guess I'm saying you might want to avoid the built-in USB charger outlets, if you plan to boondock at all.
