I was thinking about doing this with the alde. Fluid change 21 400
1 Uncap the tank.
2 Remove Red plug under trailer.
3 Let drain in a clean bucket
4 Measure the amount of Rohmar fluid drained.
5 Compare to what system holds, I am not sure of the amount of fluid in the system.
6 If the amount of drained fluid is very close to system capacity would it be safe to just refill and call it done.
7 If this way would work I would replace at a yearly interval.
I had it done in 24 at my dealership.
I am looking for any input or tweaks
Thanks for your time.
2021 t@b 400 boondock
0 ·
I've seen those numbers thrown around, even from some nuCamp sources, but it seems high. I've read that the furnace capacity is about a gallon of glycol, so even with a quart in the expansion tank, that would leave around 2.5 gallons in the plumbing. If my math is correct that would be about 80 feet at .875 inside diameter.
The reason I question this is that (even though I've altered my system) I drained less than two gallons. After draining I dismantled a lot of the system, so I'm pretty certain it was mostly empty. That would mean maybe 30 feet of plumbing would get me to the two gallons, which sounds about right.
I'm curious how much others have been able to drain from their 320 Alde systems?
For anyone else with a 320, I found this over four year old post that agrees with my math ...
2020 Tacoma TRD Off-Road
Thanks.
