Should/can I seal the back of this camper to keep leaves and water out of this groove?
Hey y'all. This is a 2023 320S Signature Series, which is most of a boondock with different trim.
As you can see, the back of this camper has a groove that collects leaves, soon to be filled with pollen, and also water I assume. I was musing on a way to block out the leaves and a friend suggested clear sealant. Maybe? But I don't know whether this would block off venting for all those machines under the seats in the back of the camper, or if this is snap off stuff that might be necessary to remove if you need repairs. Any suggestions?
I have cleared it out numerous times but the tree doesn't care.Thanks, y'all.
  • BillJ70BillJ70 Member Posts: 34
    I'd probably just buy a cheapo cover-- and at least keep it on for leaf season or when it won't be used for a while.  I don't think you'd have much luck with sealant back there-- too much of a gap and too much flex with travel.
  • HappyCamper2024HappyCamper2024 Member Posts: 44
    We live in a really humid place and the general consensus seems to be that  a cover is a recipe for mold. The leaf fall is several months, so that would be a lot of cover time.
    Thanks for the info on the sealing. My only thought is that it doesn't have to be perfect to keep leaves out but I guess it could allow water in and prevent it from evaporating. Maybe I should just put some masking tape over it and remove it when we travel.
    edited February 2025
    We had a 320 in a super humid area too (and kept it covered).  We kept a cheap dehumidifier inside (I ran seperate power cord just for the dehumidifier so I wasn't powering the whole camper - ran it through an opening in the nautilus box).  You can put the dehumidifier in the shower and not have to worry about it leaking, etc.--- just open your gray tank and let the dehumidifier empty down the drain.  Honestly, I would do this regardless of where I lived (except maybe the desert)-- just nice keeping it 50% in there.  And really, unless you have the cover really tight, enough air gets under there that we never had any mold or mildew on the outside of the camper either.  And the outside stayed cleaner.  Just one thing though-- you'll want to cover your windows with some saran-- some of the covers will scratch that lexan.
  • DerecoDereco Member Posts: 95
    I think a removable cauling/sealant might work, and you can leave gaps very half foot or foot if you want some water to drain through.  Some of those sealants are also transparent...
  • BlueespyBlueespy Member Posts: 260
    I live in Florida and use a cover whenever we put our t@b in storage.  The cover is loose fitting so air can flow under it.  Our t@b is a 2019 and looks as good as the day we brought it home in 2019.
    2025 Haven 220
    2020 Ford F-150 XLT (V-8)
    Niceville, Florida
  • MickerlyMickerly Member Posts: 481
    We keep it covered when not in use. The ceiling vent is open about and inch and all three windows are at least in the vent position. In the summer, the windows are open an inch too.
    2018 320CS-S
    "Just Enough"
