Thanks
qhumberd
Moderator
Thanks
qhumberd
Moderator
Ground Clearance on 2021 320S
MichTejLou
Member Posts: 2
Can't find a thread with this?
Which model? The "Boondock" model, with the slightly "pitched" axle, or the standard model without a "pitched" axle?Have a look at these threads and see if anything helps.
Towed by 2014 Touareg TDi -
Note that the lowest point is actually the bottom of the jack - which is why so many get a Jack-e-up so they can remove the thing before they bend it
TV:2019 Nissan Frontier PRO-4X With an Old Man Emu liftTrailer: 2019 T@B 320 Boondock with a Lock&Roll Coupler & Jack-e-upCustom fabricated metal bottom claddingCalifornia, USA -
The tape is at 9" (the case is 3") = 12 " clear at the rear axle with the T@B setting level. The prospective in the photo eludes to lower clearance beyond, but at the rear axle is the lowest point. My metal bottom looks a little different, but it fastens to the bottom of the cold rolled frame like the stock plastic cardboard. I have 235/75/r15 tires with a stock "pitched" axle. My step measures 14-1/4" from the bottom of the frame to the ground.- I have no idea what the dimension on that link was measuring. My waste pipes have more then 12" below them. I believe the 2021's are the same - hope this helps
It is non-Boondock.
The Boondock model only increases clearance by 3-4 inches.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 916 Introductions
- 72 Teardrop Groups & Links
- 913 Tips & Tricks
