My next decision I am facing in my boondocking setup is do I purchase an additional 100 watt lithium battery (200 watt total) or go with a 100 watt solar generator with a solar panel. Both are the same cost. If I chose the battery I would probably still need an additional solar panel. These will be used on a 2023 320 boondock to supplement the 100 watt lithium battery and 180 watt roof solar. I am looking to boondock 3-4 days, parked in the shade, use fridge, limited lights, charge phones, and watch tv 3 hours or so. Thank you all for the info, the people on this forum have been extremely helpful and knowledgeable.
0 ·
2020 Tacoma TRD Off-Road
Go CAMPING and see what happens, worse case you will have a night or two of 'Gosh we don't have power" but you will be Okay (survive) after a few outings you will learn what 'your style of camping' requires for power
Then it is time to think about Batteries, solar panels, etc . . .
For myself I dreamed/expected I'd be doing days & days of off-grid camping while my actual - real world 'camping' has been mostly at private RV Parks or basic service Nations Park/Forest locations; most with 120VAC service.
If you're comparing the pricing of Battle Born to a power station built offshore, it's not apples to apples. Today there are other brands of LiFePO4's that are built equally as well at a fraction of the cost. Keep in mind that at this time almost all of the components are coming from offshore, regardless of the name on the label.
John, Northern California
I would consider a battery upgrade before the purchase of a power station.
2020 Audi SQ5
I liken this to moving into a new home. The impulse is to furnish it right away but you need to use and live in it for months before you have an idea of your needs.
I like the portability of a power station and it provides boondock AC power without adding an inverter to the trailer. The power station also keeps our portable DC cooler running without modifying our cigarette lighter ports and potentially draining the vehicle's battery. I can also use the power station to run the AC portion of our house's gas boiler so we can have head during a winter power outage. Power stations have a lot of uses.
With the Bluetti Charger 1, we can non-solar charge with no noisy and expensive generator, and we have battery-powered cooler (with freezer) capacity for many more uses than just camping with the trailer.
2023 T@B 320 S Boondock
