Anyone know how to get these Tab 400 side maker lights off?
2025 Tab 400.  I am trying to install cameras in their place.  They also have moisture trapped inside already which is annoying.
    edited March 2025
    @nartmot, see the first post by @DesertDweller in the following discussion thread:
    https://tab-rv.vanillacommunity.com/discussion/comment/111916#Comment_111916
    Also, see the following discussion thread to see what it looks like after removal:
    https://tab-rv.vanillacommunity.com/discussion/14054/water-again-in-amber-sidelight#latest
    Read through those posts to see if you can find any additional info that may help you.  (NOTE:  Your trailer should still be under warranty, so you can probably get replacements from your dealer, or nuCamp, but start with the dealer.)
    P.S.  Just out of curiosity, why are you seeking to install cameras in that location.  The side markers/running lights are a safety feature to make your trailer visible at night, or during inclement weather.  I also use them to assist me when I am backing the trailer in the dark.  You should check the laws for your state, but it may be that those lights are required per the vehicle code.
  • rfuss928rfuss928 Member Posts: 1,147
    edited March 2025
    They are probably glued in place with Geocel sealant. I know that is how my tail lights were installed.
  • nartmotnartmot Member Posts: 10
    Thanks @Bayliss.  Ok so just pry the chrome part off and that should give me access to the mounting screws.
    I am replacing the side markers with cameras that also double as side markers.  I think it should help a lot when I don't have a spotter available.
    I love this community.
    Interesting, @nartmot.  I did not realize they made cameras like that.  Looking forward to hearing/seeing how it works out for you.
    @Bayliss here is the bundle I got: https://www.amazon.com/Haloview-Wireless-Backup-Camera-Cameras/dp/B0CWR951QP
    Just finished installed the rear camera just below the stargazing window, which required removing the window frame and the fabric headliner.  It was not as straightforward as I had hoped but I am pleased with the result.  Hoping the side markers are a lot easier.
    Quick update for anyone doing a similar upgrade.
    There is a pry point on the bottom right of the side marker.  I put an old credit card at the fulcrum point while prying to protect the finish of the camper.  It is indeed glued on so after I removed the screws I used said credit card to wedge in and work my way around the marker, freeing it from the glue (hot glue).
    Pry point
    Old wiring
    New camera/marker
    @nartmot, thanks for the update and pry-point info, which is good to know.  Looks like you did a nice install.  Pretty slick.
