Read through those posts to see if you can find any additional info that may help you. (NOTE: Your trailer should still be under warranty, so you can probably get replacements from your dealer, or nuCamp, but start with the dealer.)
P.S. Just out of curiosity, why are you seeking to install cameras in that location. The side markers/running lights are a safety feature to make your trailer visible at night, or during inclement weather. I also use them to assist me when I am backing the trailer in the dark. You should check the laws for your state, but it may be that those lights are required per the vehicle code.
Thanks @Bayliss. Ok so just pry the chrome part off and that should give me access to the mounting screws.
I am replacing the side markers with cameras that also double as side markers. I think it should help a lot when I don't have a spotter available.
Just finished installed the rear camera just below the stargazing window, which required removing the window frame and the fabric headliner. It was not as straightforward as I had hoped but I am pleased with the result. Hoping the side markers are a lot easier.
There is a pry point on the bottom right of the side marker. I put an old credit card at the fulcrum point while prying to protect the finish of the camper. It is indeed glued on so after I removed the screws I used said credit card to wedge in and work my way around the marker, freeing it from the glue (hot glue).
https://tab-rv.vanillacommunity.com/discussion/comment/111916#Comment_111916
Also, see the following discussion thread to see what it looks like after removal:
https://tab-rv.vanillacommunity.com/discussion/14054/water-again-in-amber-sidelight#latest
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePo4; Solar: Renogy 100Ah Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
I love this community.
Pry point
Old wiring
New camera/marker
