Vacuum
I have a 320 and want to get a rechargeable vacuum for it.  Want one fairly small, rechargeable, and will work on both the floor and cushions.  What is everyone using?
  • Bill&Suze
    Bill&Suze Member Posts: 179
    My wife did her research and found this https://levoit.com/products/lvac-200-cordless-vacuum for trips in our 400. It can be broken down into shorter lengths for versatility and comes with a crevice tool and 2 in 1 pet tool brush.The power nozzle itself does a good job of doing the floor and has no problem picking up copious dog hair.
    Susan & Bill, Yarmouth, Maine
    2024 Kia EV9
  • TourDeForth
    TourDeForth Member Posts: 133
    edited March 2025
    I’m using a RIDGID 3 gallon 18v cordless. I chose it because it’s light weight and wet/dry, so suitable for any issue. It’s also strong enough to store my blankets and pillows in a vacuum bag to save space. It uses the same battery for my cordless drill/driver that I use on the stabilizer struts. I had a little 12v auto vacuum but it sucked because it didn’t suck! Lol, it also broke easily.
    edit to add: another thing I like about the rigid portable vacuum is the hose can be reversed and turns it into a blower, that comes in handy often!
    John, Northern California
  • marleecamps
    marleecamps Member Posts: 180
    I use a Bissell portable vacuum in my T@b400.  https://www.target.com/p/bissell-pet-hair-eraser-lithium-ion-hand-vacuum/-/A-53425852.  Does a respectable job of keeping things tidy , especially with my corgi on board.
    --Marlee
    2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota
  • AnOldUR
    AnOldUR Member Posts: 1,764
    This might not be the size you had in mind, but we use this little car vacuum cleaner that has USB charging. We will usually sweep first and then use it to get the fine dirt that remains. A great side benefit is using it to suck up any mosquitos, flies or other bug that make there way into our T@B.
    https://www.amazon.com/dp/B09JNX6VC4?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_3&th=1
  • rfuss928
    rfuss928 Member Posts: 1,197
    edited March 2025
    This is the newer version of the vacuum we ended up with ~12 years ago and itis still going strong.  We gave up on 12 volt or cordless as they just didn't perform to our expectations.
    This is very compact (about the size of a soda bottle) and very powerful with a easy to empty or replace filter.
    https://metrovac.com/products/vac-n-go-500-watt-hi-performance-hand-vac?variant=46250504585509
  • elbolillo
    elbolillo Member Posts: 575
    I was able to find a Hitachi (Now Metabo) vacuum that uses the same 18v batteries as the hand tools that I have. Work great. Very good suction.
  • ckjs
    ckjs Member Posts: 144
    We use a Makita vacuum (which is quite similar to @elbolillo's) since my other tools are theirs.
    If you have cordless power tools, check out whatever 'stick' vac option that brand has.
  • Towhee
    Towhee Member Posts: 55
    We use a Ryobi hand held.  Very convenient that same rechargeable battery is used on the inflation tool and the drill motor.
