Of all the mods I’m getting ready for (once we get our 400) the battery monitor is high up on my list. My question is how difficult is it to run the wiring from the battery to the front door location where all of the other control panels are? I could more easily install it by the bed but my OCD demands that it be next to all of the other panels.
2021 400 BD
2020 Tacoma TRD Off-Road
0 ·
Routing the display wiring isn't too difficult. If you look behind the kitchen sink you'll see a horizontal black PVC pipe that's the conduit for the wires going to the controls next to the door. Pull the drawers out between the sink and the frig (if installed) to follow the conduit. Depending on how OCD you are, you can just zip tie the display cable to the outside of the conduit, or try to run it inside the conduit.
So far it works great, and I am going to put the monitor on the panel below the television above an outlet that is there. Helps my OCD to not have it in my line of sight during the day, but able to check at night when I get that feeling that I need to see how many amp hours are left😊
pics of my location and information at the thread below
Bluetooth ones make that a non issue but my other Bluetooth accessory is a propane monitor that never seems to connect reliably. So I am still ok with a wire.
I'd appreciate information on what specs we need for the jumper wire connecting the negative terminal to the B-side. Is a 1/0 copper cable sufficient? We have the original 1200W/2400W surge inverter that came with our 2022 400 BD if that matters.
2024 Toyota Tundra SR5
In short, You are Correct on the wiring.
Note:
A] the 'short' wire from shunt B- to battery negative side does not have to be short.
Place the shunt at any location that works for your set-up.
B] As for the B- Shunt Side wire size/gauge . . . you will be fine using the same size as the trailers
original ground to battery wire, or if you like one size larger. They is no need for a giant
diameter 0/1.
For Reference:
For my 320S, with the same Current Monitor installed.
I have a same Bus Bar connected to the P Side, that Bus Bar has all the 'extra' wires that were on my rig's battery ground terminal.
I'm surprised that 'white wire' goes to the Alde.
In general a direct (extra) Alde ground to the battery was a quick-fix for model 3010 [two green fuses on Alde] to reduce the Alde ground side fuse from failing. Your rig has a model 3020 which eliminated the ground side fuse issue
Are you sure the 'white wire' does not go to a solar controller; that would be more typical.
2024 Kia EV9
