getting bearings repacked today and new seals and break check. tomorrow new tires. just read the manual and it indicates 90psi torque on the lug nuts of by 2021 tab 320s boondock with 15 inch aluminum wheels. Is that was everyone thinks is the proper setting. I thought it was 100psi
0 ·
Tire pressure is commonly measured in psi. Torque is commonly measured in foot-pounds.
I torque the lug nuts on my 2020 T@B 400 (with aluminum wheels) to 95 foot-pounds.
Then, after towing around 100 miles, I re-torque at 95 foot-pounds.
To enable quick visual checking of lug nuts, I mark each nut with a small dab of paint after the re-torque. That way, I can easily see if a nut is backing out, without bothering to use a torque wrench each time I want to check my lug nuts.
My understanding has been that, in general, aluminum wheels should be torqued between 90-100 lbs. However, if you do a search online, you will see a range between 90-120 ft lbs of torque for a 1/2" lug nut on aluminum wheels with a 5 on 4.5" bolt pattern, like the Boondock wheels.
This discussion thread may be of interest to you:
https://tab-rv.vanillacommunity.com/discussion/comment/78577#Comment_78577
It's made regular wheel rotation on my truck much easier. The Tacoma only gets 83 ft lbs, surprising the smaller studs on tab take higher torque.
Both sets are steel.
Car manufacturers arrive at their numbers in different ways, taking in account the rotors/drums etc.
