Progressive Industries EMS-HW30C install
2»
  • SLJSLJ Member Posts: 613
    Never had any noise or hum from mine. Just put a second one in a new camper and no noise from that one either. No hum at all.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2023 Ford Maverick XLT
    The Finger Lakes of New York
  • FreespiritFreespirit Member Posts: 169
    Second @SLJ, original HW30C installed 5 years ago and no hum at all.
    2020 TAB 320 U
    TV 2022 Highlander
  • subkronsubkron Member Posts: 184
    I installed mine behind the electrical panel in my 400 and located the remote display in the nautilus compartment on a side wall.  The display is way to bright and having it in the nautilus which is adjacent to the shore connection it is easy to check when I power up.
    As far as the noise, my original EMS had the hum as well which was a bit annoying.  I called PI and ended up getting a replacement, they were pretty good about it.
    2022 T@B 400 Boondock
    South Jersey
  • valkraidervalkraider Member Posts: 25
    With such a small space and as hard as it is to get to things, I have no interest in trying again and potentially having the same problem. My body still hurts from the contortions it took to do the first one.  ;)
  • MaxcampMaxcamp Member Posts: 320
    Ditto on the hum.  45 dB about right.  Very annoying, my ears ring.  Neoprene isolator washers keep it from vibrating plywood.  Under the foam bed dampens a bit.
    The device has a bypass if shore power is under or over voltage thresholds.
