Hello! I need to replace the latch that holds the small access panel door shut that is located behind the toilet in my 2019 320S. The latch came apart and parts fell down into the belly of the camper, not to be retrieved, and now the door will not stay shut. I've asked my local dealer for a replacement but they say NuCamp operates by email and they want a picture. My camper is at my lake house in MN, and I am in Colorado till summer.
So...does anyone have a picture of this latch, or know where there might be one archived? Or know of an Amazon level replacement that would work?
Thanks!
John
0 ·
You can also do an online search for "RV compartment door thumb latch" or "RV compartment door twist latch" or similar terms.
If you find a matching latch, you may have to separately purchsase the "finger pull" that works with the latch, such as this one from Amazon:
https://www.amazon.com/RV-Designer-L539-Finger-Pull-Compartment/dp/B0020YP00O/ref=asc_df_B0020YP00O?mcid=0e34c0511a3b38dba0dcd26e6755d5db&hvocijid=10412718452061822724-B0020YP00O-&hvexpln=73&tag=hyprod-20&linkCode=df0&hvadid=721245378154&hvpos=&hvnetw=g&hvrand=10412718452061822724&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9220048&hvtargid=pla-2281435177658&psc=1
Good luck!
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
