Recently Dewinterized my 2021  T@B 320CSS.  Worked well.  Flushed all the lines using the city water setting on the Nautilus  2.5.  Then changed the Nautilus to fill fresh water tank.  Added 10 gallons, per the flow meter.   Flushed all the lines again using the water pump.   Drained all the water out and opened the Alde/Hot water bypass.  I did not sanitize yet.   2 days later I refill the freshwater tank using City Water, again 10 gal.  Nautilus is then set to DryCamp.   When the pump is turned on water is briskly flowing from the fresh water tank vent.   It was flowing under pressure.  At least 3 gallons/min.
Not sure what to do.  Any suggestions.
Thanks Edward.
                1 ·
#1 - Black corrugated 2 inch drain is for the AC condensation. #2 - Alde Drain from the yellow Safety/Pressure valve under the driver side bench. #3 - Fresh tank overflow. #4 - Alde condensation and bleed drain (follow the hoses from the Alde - 2 should exit through the floor and drain at this point.)
by putting the flap in the down position (forward) the and turning back on the water with the pressure proection the sinks work again.
thanks for sharing.
