2024 and 2025 NuCamp owners.....What model of WFCO do you have?
pthomas745
pthomas745 Administrator, Moderator Posts: 4,579
Are they still using the WFCO "Auto Detect" Models?
If so: are the newer trailers coming with the older "problematic" auto detect models without the "jumper fix" that rolled out last year sometime?
Or, are they upgraded with the "jumper" that simply tells the WFCO "charge lithium only"?
This thread has a long discussion, but on the last page is a photo of the WFCO including the model number and a firmware version.
It would be nice to know if the trailers are being shipped without this "known problem".
Here is a thread with pictures of the "jumper" that simply tells the WFCO to be a lithium charger only.
  • aditto
    aditto Member Posts: 7
    2025 Tab 400 - Black Canyon with Convenience Package
    WF-8955-AD-WAGO
    Not all 2025 Tab 400s come with this, especially if they don't have the lithium battery added by convenience package
  • donmontalvo
    donmontalvo Member Posts: 187
    edited May 2025
    2024 320S Boondock Black Canyon. Came with a single 100ah LiFePO4 battery, a 100|30 MPPT, and a 500A|50mv smart shunt. I added a second battery, a second MPPT, and an inverter. I might go to an RV park once every couple or few weeks, and I know the AC, microwave, etc., all work.
    Unsure how being on shore power charges the LiFePO4 batteries, if it does it, and if so how, does that work, etc. Is there a way to confirm? When I'm driving I'm guessing my vehicle heavy duty alternator is sending some power to the camper batteries (guessing not much). When I'm boondocking, the batteries are being charged by solar.
    I have thought about confirming if power is sent to the camper battery when the Jeep is off, and maybe installing a DCtoDC in the camper, and running a dedicated wire from it to the Jeep's heavy duty alternator. I hate that I'd have to handle connecting and disconnecting the wire though.
    Here is my WFCO 8735...the cover shows Firmware "V1.19", assuming the sticker is correct.
    @donmontalvo - to know if your AD converter is in lithium mode, plug into shorepower and check for a blue light near the bottom of the DC fuse panel.
  • B0atguy
    B0atguy Member Posts: 260
    edited May 2025
    2024 400 - It has the standard WFCO WF-8955-AD-WAGO . Initially , all I could get was the green light . I was patient , and eventually it did finally "Auto Detect" , and switched over to a blue light all by itself . At first I did contact WFCO to inquire about getting the "jumper" to lock it into lithium mode, but they were unhelpful . Just sent me an email with about 25 nonsensical questions thinking I was doing something wrong . While waiting for help from WFCO , the charger did change over to blue on its own . Just had to be patient I guess . Now its blue everytime I check it , and the occasional red light indicating bulk mode when the battery is "low".
  • donmontalvo
    The camper came new with LiFePO4. I very rarely use shore power, but I will check the next time I do. Thanks for the info, noted.
    The reason I brought this up is that a couple of owners of 2024 and 2025 trailers over on the FB page are asking about why their shunts are not "synchronizing".  Of course, there were several Victron controllers and shunts that were not configured for lithium charging, or had the wrong battery setup.  (A continuing problem!)
    One owner's controller and shunt were configured properly, and they had the trailer on shore power for a few days.  With the WFCO "blue light on".
    But: the WFCO would not synchronize their shunt settings, since (I have to take their word for this) the WFCO was reaching the "charged voltage" and then immediately dropping back below that number.  The shunt requires at least three minutes at the "charged" voltage value to synchronize.
    A call to WFCO and the owner got the same old advice: run the battery down to a certain lower level. They suggested dropping it about 20-30 amp hours, instead of the advice from a couple of years ago to bring the battery all the way down to 10 percent, etc.  And then let the WFCO "auto detect" the battery.  This is with the "blue light" constantly on.
    The firmware version on this owner's trailer (a 2025 Tab 360) is V1.21A.
  • elbolillo
    elbolillo Member Posts: 560
    WFCO needs to ditch the auto-detect  feature and simply provide a physical switch, or better yet NuCamp should switch to Progressive Dynamics converters.
  • Gomers2
    Gomers2 Member Posts: 145
    edited May 2025
    Deeper in the settings you can reduce the sync detect time from 3 minutes to 1 minute. However mine still doesn't sync. It hits charged level and drops back to hold level right away, as described above. I gave up the effort and did it manually in a way. Charge to 14.4 and manually set the state of charge to 100% at that time.  So far it's been quite accurate; everything in and out of the batteries counted so it's reliable in that sense.  (I am on blue light LiPofe mode with jumper.)
    @Gomers2 resetting the "charged detection time" is a good strategy, as is doing the sync manually.    Battleborn, in their "BMV settings" page, claims that the "charged detection time" should be three minutes.  Hence...a lot of confusion by new owners who want to "protect" their battery investment.
  • Gomers2
    I am almost positive that detection time suggestion came from Victron tech support. He walked me thru optimal settings in the advanced menu when I was dealing with the WFCO AD "feature." But it's moot; it only stays at 14.4 for < 1 minute and does not sync per se. But I'm comfortable with that because the charger is bringing the 🔋 up to proper voltage, then backing off to full storage level, the SOC seems accurate, and everything works as it should.
  • HappyWanderer
    HappyWanderer Member Posts: 28
    2024 320 CS-S Black Canyon - WFCO 8735-AD Firmware: 1.21A
    No blue light near DC fuses.  Red and green lights when first plugged in then red light went out.
    2024 320 CS-S | Ontario, Canada
    If it is green, then the AD did not kick in and it is charging on the Lead Acid profile.
  • HappyWanderer
    Funny thing is that I could have sworn I saw a blue light a couple of days ago (I remember thinking "what the heck is that about?").  Right now the battery is topped up (13.75V), I'll pay close attention the next time it drains down a bit.
  • LauraC
    LauraC Member Posts: 35
    Mine has a blue light ... but it's still not charging to 14.4 or even 14.2 for long enough to top balance the lithium battery when on shore power.  I realize there's disagreement over whether top balancing is necessary - but Battleborn seems pretty sure it is - to ensure battery is working as well as it can for as long as it can.  I'm probably going to buy a Victron IP65 battery charger and have it permanently installed at a local dealer who I trust.  They said they can bypass the WFCO charger.
  • HappyWanderer
    Let the battery drain down to 70% overnight then plugged the camper in this morning - got a brief flash of blue from the WFCO then right back to green.  Given the well documented problems with the auto-detect one wonders why NuCamp persists in using this converter.  LauraC I think you have the right idea with the separate charger.
  • JEB
    JEB Member Posts: 268
    Sorry to be joining this discussion so late, but what do you have your Charged Voltage set for in the Victron App?  If it’s set for 14.4V (and that’s what it looks like in your chart), that’s too high.  According to Battle Born, it needs to be set for at most 0.2V below the voltage the converter is designed to reach.  So, if the WFCO is programmed to charge your batteries to 14.4V, the Charged Voltage should be set no higher than 14.2V.  Then the automatic SOC sync to 100% should work normally without the need to do it manually even if the charged detection time were reset to the full three minutes.  I strongly doubt that it would take less than three minutes for your converter to charge your batteries from 14.2V to 14.4V and then float back down to 14.2V.
  • Gomers2
    Interesting, thanks. Mine is set to 14.4v .  I just double checked the settings configuration email I got from Steve C at Battleborn and his recommendation is to set charged voltage to 14.4v.  The statement that the voltage needs to be "at most .2 v below converter voltage" is slightly ambiguous. You could read that to mean: "set at 14.4, or slightly below, but not more than .2v below.".   But I'll try mine at 14.2.   The shunt accurately counts the aH in and aH out, so the SOC sync would be nice, but not really essential.
  • SLJ
    SLJ Member Posts: 651
    This has been going on since 2021. WFCOs are junk. Should have just kept the battery type switch.
    Just put a battery switch after the shunt and add a Victron Smart Charger. When plugged into shore power turn the batteries off and let the Victron do the charging.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
  • JEB
    The recommendation from Battle Born often depends on who you talk to.  The tech I worked with recommended 14.2V.  So does this programming guide.  https://battlebornbatteries.com/how-to-install-and-program-a-battery-monitor/?srsltid=AfmBOop9LC5dr7aeYeInM5_aQg30c92f7m6Mbhvg2_bmq6-xAVUN68D3.  Part of the confusion comes from the fact that many manufacturers of lithium batteries revised their charging specifications in 2023, reducing the top end recommendation from 14.6V to 14.4V.  As a result, anything based on the top end spec also needs to be adjusted.
    14.2V and three minutes detection time has worked well for me for both WFCO and Progressive Dynamics (what I’m currently using) converters.
