Has anyone used the Champion 2500 on propane, at elevation (4-6,000 ft) to run the Air8 and if so, were you successful? I’d ideally like to stay with a 2500 size generator due to the weight, so would consider other options as well, but would prefer to stay with propane. Thank you for the feedback!
1 ·
1665 watts at 120v is 13.7a. This is slightly less than a single home outlet, or about one appliance. Engine output is related to air density which is based on altitude. You typically lose 2 to 3% power output for each 1000ft assuming the temperature is constant. The manufacturer's numbers are based on a new, properly running motor. Using propane will produce these values longer than gasoline.
My guess: it may work in the mountains for charging the battery. For running the air conditioner, it may not if anything else is also on. The math says it is sketchy. Reality and math aren't always in agreement. The real test is to try it. Do you know someone that has one you could try?
I do understand the desire to not get the larger 30a generators. 30a is 3300 to 3600w. That's a lot more size, weight and fuel. The benefit is the ability to operate the trailer without restrictions.
"Just Enough"
I have since installed a "soft start" on our Cool Cat , and now the 2200i runs the A/C with no trouble what so ever . Even on "eco" mode, we have no issues . Very light, VERY quiet , very reliable . Ok, maybe its a little more expensive too, lol , thats literally the only downside .
Really , there is a reason why EVERY other generator is compared against the Honda. Its the gold standard . I am SO glad we decided on the Honda . Its the perfect combination for any NuCamp when coupled with the Hutch Mountain propane kit (VERY easy to install !) , and a soft start on the A/C unit.
The soft start was also a huge improvement on its own . The A/C runs better on shore power and with our 400ah batteries / 3000w inverter . The A/C runs quieter and doesn't have that loud surge when the compressor kicks on . Love it !
Good luck in your search , but its worth your time (and extra $$$) to give serious consideration to the Honda .
2024 NuCamp T@B 400 BD, Charcoal / White
I keep a 5 gallon fuel container strapped to my spare wheel, and I fill it when I get gas for my Jeep. Power, weight, and size were a deciding factor. Running power is 1850W for gas, and 1665W for propane, so decided to just get the gas model.
I haven't used it at altitude yet, but will soon since it'll start getting hot in Quartzsite, AZ in a month or so. But from what my buddies tell me, the Champion 2500 runs fine at altitude using gas, no idea about propane.
https://revkit.com/donmontalvo/ | https://donmontalvo.com
With 200ah battery and 200w of solar and DC truck charger, in past two years we've only used generator after a full rainy week.
I'm now at Quartzsite, AZ where the Air8 isn't needed much, and the need will continue to go down.
I should mention I finally installed an SoftStartRV, and I can confirm that I can switch my Champion 2500 generator to Eco mode after the Air8 has been started. This combo will run for 10-11 hours without any issues.
