2017 T@B 320S Freshwater Drain Valve Replcement
FishDoctor
Member Posts: 79
The knob on the freshwater drain valve (next to entry step on passenger side) is getting hard to open and close. I am worried that the extra strain might break the PEX pipe near the connection. Does anyone know offhand what size replacement valve fitting is needed? Thanks!
Downers Grove, IL
2017 T@B 320S Max, Blue and Silver -- "The Blueb@rry"
A little penetrating oil on the valve shaft may resolve the issue.1
I'll give that a try.rfuss928 said:A little penetrating oil on the valve shaft may resolve the issue.Downers Grove, IL
2017 T@B 320S Max, Blue and Silver -- "The Blueb@rry"0 -
2017 T@B S. Valve handle broke off the freshwater drain, so I want to replace the valve. Can someone tell me what size PEX is used for the drain line so I can get the right fitting?
Downers Grove, IL
FYI in case anyone else needs to know. I cut off the existing crimp holding on the old fitting and compared it to 1/2 inch PEX fittings I had on hand. The sizes matched (at least visually). I replaced the old valve with a quarter-turn 1/2 in. Brass PEX-B Ball Valve. It was crimped with a 1/2" stainless steel PEX crimp on the back barb and the pipe behind the valve was anchored to the frame with a 1/2 inch plastic pipe clamp screwed into the same holes used by the original anchor clamp (which was cracked) with Anderson (square) screws. When I installed everything, I made sure the valve opened by pulling the handle toward the stairs and the swing to shut it off and turn it on weren't blocked by any obstructions. Not a difficult repair except for the limited space for working and cutting off the old and crimping on the new crimp ring. I think this style of valve will be easier to manipulate.
Downers Grove, IL
2017 T@B 320S Max, Blue and Silver -- "The Blueb@rry"4 -
Great idea! Those little valves can be difficult to reach and turn.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio2
FishDoctor Awesome mod. Think I'll give it a shot on my T@B.
2018 TAB 320S
2020 Honda Ridgeline RTL
North Texas
Trips - 50 Mileage - @67k
"Our favorite trip will always be our next one"0
