Thanks
qhumberd
Moderator
Thanks
qhumberd
Moderator
Broken cushion over AC
Charlessyverson
Member Posts: 37
When unmaking the bed, I broke one side of the wooden frame in the cushion over the AC in a 2023 320 Boondock. Has anyone done a repair of that before that could provide me some guidance before I tear into it? I did contact NuCamp but have not heard back for them yet. I am the second owner so not sure if I am covered by any kind of warranty for that type of situation. Thank you for the help!
Regarding the warranty question, send nuCamp an email with photos and they will let you know. Warranty@nucamprv.comSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
No warranty, repair suggestions? Is it easy enough to repair by myself or am I better off bringing it to an upholstery shop?
Maybe a photo will generate discussion.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Speaking as another used owner, Nucamp will likely tell you no coverage.
Our 2021 bedcushion frames promptly broke when kneeled upon, as well.
Extremely poor design and assembly- stapled through endgrain of poorly selected softwood. No joinery.
An upholsterer can rebuild the frame.
The tragic sleeping cushion arrangement has led many, including us, to amend or entirely replace the system.
https://tab-rv.vanillacommunity.com/discussion/15144/a-truly-flat-heated-bed
2021 T@B 320S Boondock/ 2012 Tacoma 4 cylinder truck / 2023 Tacoma 6 cyl. truck -
We have that in the back of our camper and when I look at it it's like balsa wood. Complete and total crap in there I don't wanna peel the entire cover off so my intention is to peel off that bottom dust protector and get a piece of plywood cut that will fit an inset in that hole. I'm gonna try to drill sideways some wood screws but if not I'll reinforce it as well with flat brackets. I'll take pictures when I do it.2019 Custom T@B 320 U Boondock Lite-ish
- 916 Introductions
- 72 Teardrop Groups & Links
- 913 Tips & Tricks
