recurring freshwater and pump problems 2025 Tab
New Tab 360 pump kept running.  Dealer tech said air leaking in at filter bowl near pump
and tightened bowl. On next campout indrycamping modepump againranforeverand air in water lines.
opened up are under bed.   fitting to pump loose.   tightened.   ran pump.  could see airleaking
into clear filter bowl.   tightened clearcover.    freshwater ok now.   looks like has to bechecked
everytrip
  • jkjenn
    jkjenn Member Posts: 6,425
    Reach out to the nuCamp customer experience team. It shouldn't be doing that.
    @levbob - email help@nucamprv.com.
  • levbob
    levbob Member Posts: 27
    It failed again a few hours later - leaking air into filter bowl - can see the air entering.  Will order new filter.
