Hi
can someone please advise on battery connection. I’ve never had a leisure battery as I’ve always used a site with a plug in. I purchased second hand in immaculate condition about 15 years ago. It is still in immaculate condition!!!!! I’m wanting to use the fridge and lights from the battery but I have no idea where to start.
Ive never had a battery. It’s a two way fridge which was originally installed in the T@B. Not sure how and where to connect a battery. I will post photos later (tomorrow)if this would help.
Will your inside lights work while towing?
Knowing that @Caravaggio rig is in the UK is a major factor
(not many EU folks post on this forum [ Welcome ] ).
The Dometic MK-60 shown in an earlier picture would be the AC voltage to DC Voltage Convertor only, not a Power Center with Battery Charger that is standard in North America rigs.
Based on the pictures and @Grumpy_G research this rig does not have a factory installed Battery and cannot fully operate without 230/50Hz VAC Shore power.
Fridge { Make, Model, year ] and how long @Caravaggio would like to have cold food when not having access to 230VAC Shore power.
This is a doable 'project' but will not be a cheap or totally easy project.
